[GRASS-user] Import Shape Files
Markus Neteler
neteler at osgeo.org
Thu Jul 2 11:26:40 PDT 2020
Hi Martin,
On Thu, Jul 2, 2020 at 1:57 PM Martin Bittens <martin.bittens at gmx.de> wrote:
> Hello Markus,
> ok, let us try.
> Attached I send (as zip files):
> 1.) QGIS_LT_AOI_3.zip with a shape layer created in QGIS 2.14.0. It
> contains contains 5 sample points extracted from an existing site (EPSG
> 31983);
> 2.) Test_SG.zip with the files from the grassdata directory created by
> GRASS 7.8.3 after establishing the location "Test_SG" (EPSG 31983) and
> importing the shape layer into "Test_SG".
I tried and got this:
# create new location from SHAPE file:
grass78 -c LT_AOI_3.shp ~/grassdata/sirgas_2000
Starting GRASS GIS...
Creating new GRASS GIS location <sirgas_2000>...
Welcome to GRASS GIS 7.8.4dev (0798df3d0)
GRASS 7.8.4dev (sirgas_2000):/tmp > g.proj -w
PROJCS["SIRGAS 2000 / UTM zone 23S",
GEOGCS["SIRGAS 2000",
DATUM["Sistema_de_Referencia_Geocentrico_para_las_AmericaS_2000",
SPHEROID["GRS 1980",6378137,298.257222101,
AUTHORITY["EPSG","7019"]],
TOWGS84[0,0,0,0,0,0,0],
AUTHORITY["EPSG","6674"]],
PRIMEM["Greenwich",0,
AUTHORITY["EPSG","8901"]],
UNIT["degree",0.0174532925199433,
AUTHORITY["EPSG","9122"]],
AUTHORITY["EPSG","4674"]],
PROJECTION["Transverse_Mercator"],
PARAMETER["latitude_of_origin",0],
PARAMETER["central_meridian",-45],
PARAMETER["scale_factor",0.9996],
PARAMETER["false_easting",500000],
PARAMETER["false_northing",10000000],
UNIT["metre",1,
AUTHORITY["EPSG","9001"]],
AXIS["Easting",EAST],
AXIS["Northing",NORTH],
AUTHORITY["EPSG","31983"]]
To me it looks as expected.
My software versions:
g.version -rge
version=7.8.4dev
date=2020
revision=0798df3d0
build_date=2020-07-02
build_platform=x86_64-pc-linux-gnu
build_off_t_size=8
libgis_revision=8e4dab571
libgis_date=2020-05-05T09:05:27+00:00
proj=6.3.2
gdal=3.0.4
geos=3.8.1
sqlite=3.32.2
Might it be that your PROJ installation is somehow broken?
best,
Markus
