[GRASS-user] Raster map - unsupported compressor error
Maris Nartiss maris.gis at gmail.com
Fri Jul 24 01:04:29 PDT 2020
ceturtd., 2020. g. 23. jūl., plkst. 16:01 — lietotājs Micha Silver
(<tsvibar at gmail.com>) rakstīja:
> So to make rasters in 7.8 and have them available in 7.2 you will need to set the GRASS_COMPRESSOR environment variable in advance to "ZLIB" before creating the rasters in version 7.8. THen those should be readable in older versions.
You can also use r.compress in 7.8 to recompress existing maps with
different compression algorithm (ZLIB). A good idea to save some disk
space taken by old maps.
https://grass.osgeo.org/grass78/manuals/r.compress.html
Māris.
P.S. Why do you want to use 7.2 if 7.8 is working fine on your system?
