[GRASS-user] v.centerline addon
Moritz Lennert
mlennert at club.worldonline.be
Thu Mar 5 00:10:17 PST 2020
On 4/03/20 18:10, cesar at fototerra.com.br wrote:
> Hello!!!
> I’m new user on GRASS and I’m trying to execute the addon v.centerline
> on GRASS 7.9. As input I’m using a shapefile containing line
> (MultiLineString) as geometry and when I have run the v.centerline an
> erro is returning:
> *“Traceback (most recent call last):*
> * File "C:\Users\cesar\AppData\Roaming\GRASS7\addons/scripts*
> */v.centerline.py", line 319, in <module>*
> * main()*
> */v.centerline.py", line 111, in main*
> * segment_input += 'P ' + category.strip()*
> *TypeError: can only concatenate str (not "bytes") to str*
> *(Wed Mar 4 17:27:25 2020) Comando terminado (3 segundos) *
> *(Wed Mar 4 17:27:25 2020) *
> *v.centerline input=Linha_rio_teste_Centerline at PERMANENT output=teste
> range=2 refline=2*
> *Traceback (most recent call last):*
> * main()*
> *(Wed Mar 4 17:27:28 2020) Comando terminado (2 segundos)”*
> I would like help to try understand what’s happening.
I would guess that this is a Python 3 vs Python 2 issue. I never updated
the addon to Python 3. If someone else can do this, it would be great,
as I'm currently on mission abroad and do not really have the necessary
access to the development tools to do this from here.
Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200305/9156cf1a/attachment.html>
