[GRASS-user] RES: v.centerline addon
cesar at fototerra.com.br
Thu Mar 5 02:37:14 PST 2020
Hi Moritz and colleagues!!
Thank you for write and being help me. About the python version make sense
because Im using Python 3.7.
Ill try install Python 2.x and run again the addon v.centerline and Ill
tell about the result.
Tks.
César de Paula
De: Moritz Lennert <mlennert at club.worldonline.be>
Enviada em: quinta-feira, 5 de março de 2020 05:10
Para: cesar at fototerra.com.br; grass-user at lists.osgeo.org
Assunto: Re: [GRASS-user] v.centerline addon
On 4/03/20 18:10, cesar at fototerra.com.br <mailto:cesar at fototerra.com.br>
wrote:
Hello!!!
Im new user on GRASS and Im trying to execute the addon v.centerline on
GRASS 7.9. As input Im using a shapefile containing line (MultiLineString)
as geometry and when I have run the v.centerline an erro is returning:
File "C:\Users\cesar\AppData\Roaming\GRASS7\addons/scripts
/v.centerline.py", line 319, in <module>
main()
/v.centerline.py", line 111, in main
segment_input += 'P ' + category.strip()
TypeError: can only concatenate str (not "bytes") to str
(Wed Mar 4 17:27:25 2020) Comando terminado (3 segundos)
v.centerline input=Linha_rio_teste_Centerline at PERMANENT output=teste range=2
refline=2
main()
(Wed Mar 4 17:27:28 2020) Comando terminado (2 segundos)
I would like help to try understand whats happening.
I would guess that this is a Python 3 vs Python 2 issue. I never updated the
addon to Python 3. If someone else can do this, it would be great, as I'm
currently on mission abroad and do not really have the necessary access to
the development tools to do this from here.
Moritz
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200305/2e7c6f9b/attachment.html>
