[GRASS-user] RES: v.centerline addon
Moritz Lennert mlennert at club.worldonline.be
Fri Mar 6 08:34:12 PST 2020
Hi César,
Micha Silver sent a pull request that should solve your issue [1], but I currently do not have the access necessary to merge.
If one of the other developers can do it, please feel free, otherwise I'll do it on Monday.
Moritz
[1] https://github.com/OSGeo/grass-addons/commit/20f8becac918dbd2d81368e9a305e62fcb53efc9
Am 5. März 2020 11:37:14 GMT+01:00 schrieb cesar at fototerra.com.br:
>Hi Moritz and colleagues!!
>Thank you for write and being help me. About the python version make
>sense
>because I’m using Python 3.7.
>I’ll try install Python 2.x and run again the addon v.centerline and
>I’ll
>tell about the result.
>Tks.
>César de Paula
>De: Moritz Lennert <mlennert at club.worldonline.be>
>Enviada em: quinta-feira, 5 de março de 2020 05:10
>Para: cesar at fototerra.com.br; grass-user at lists.osgeo.org
>Assunto: Re: [GRASS-user] v.centerline addon
>On 4/03/20 18:10, cesar at fototerra.com.br
><mailto:cesar at fototerra.com.br>
>wrote:
>Hello!!!
>I’m new user on GRASS and I’m trying to execute the addon v.centerline
>on
>GRASS 7.9. As input I’m using a shapefile containing line
>(MultiLineString)
>as geometry and when I have run the v.centerline an erro is returning:
>“Traceback (most recent call last):
>  File "C:\Users\cesar\AppData\Roaming\GRASS7\addons/scripts
>/v.centerline.py", line 319, in <module>
>    main()
>/v.centerline.py", line 111, in main
>    segment_input += 'P ' + category.strip()
>TypeError: can only concatenate str (not "bytes") to str
>(Wed Mar  4 17:27:25 2020) Comando terminado (3 segundos)
>v.centerline input=Linha_rio_teste_Centerline at PERMANENT output=teste
>range=2
>refline=2
>    main()
>(Wed Mar  4 17:27:28 2020) Comando terminado (2 segundos)”
>I would like help to try understand what’s happening.
>I would guess that this is a Python 3 vs Python 2 issue. I never
>updated the
>addon to Python 3. If someone else can do this, it would be great, as
>I'm
>currently on mission abroad and do not really have the necessary access
>to
>the development tools to do this from here.
>Moritz
