[GRASS-user] RES: v.centerline addon
Moritz Lennert
mlennert at club.worldonline.be
Fri Mar 6 09:46:28 PST 2020
MarkusM just merged the PR so you can reinstall the extension and see if it works with your python 3 installation now.
Moritz
Am 6. März 2020 17:34:12 GMT+01:00 schrieb Moritz Lennert <mlennert at club.worldonline.be>:
>Hi César,
>Micha Silver sent a pull request that should solve your issue [1], but
>I currently do not have the access necessary to merge.
>If one of the other developers can do it, please feel free, otherwise
>I'll do it on Monday.
>Moritz
>[1]
>https://github.com/OSGeo/grass-addons/commit/20f8becac918dbd2d81368e9a305e62fcb53efc9
>Am 5. März 2020 11:37:14 GMT+01:00 schrieb cesar at fototerra.com.br:
>>Hi Moritz and colleagues!!
>>Thank you for write and being help me. About the python version make
>>sense
>>because Im using Python 3.7.
>>Ill try install Python 2.x and run again the addon v.centerline and
>>Ill
>>tell about the result.
>>Tks.
>>César de Paula
>>De: Moritz Lennert <mlennert at club.worldonline.be>
>>Enviada em: quinta-feira, 5 de março de 2020 05:10
>>Para: cesar at fototerra.com.br; grass-user at lists.osgeo.org
>>Assunto: Re: [GRASS-user] v.centerline addon
>>On 4/03/20 18:10, cesar at fototerra.com.br
>><mailto:cesar at fototerra.com.br>
>>wrote:
>>Hello!!!
>>Im new user on GRASS and Im trying to execute the addon v.centerline
>>on
>>GRASS 7.9. As input Im using a shapefile containing line
>>(MultiLineString)
>>as geometry and when I have run the v.centerline an erro is returning:
>>Traceback (most recent call last):
>> File "C:\Users\cesar\AppData\Roaming\GRASS7\addons/scripts
>>/v.centerline.py", line 319, in <module>
>> main()
>>/v.centerline.py", line 111, in main
>> segment_input += 'P ' + category.strip()
>>TypeError: can only concatenate str (not "bytes") to str
>>(Wed Mar 4 17:27:25 2020) Comando terminado (3 segundos)
>>v.centerline input=Linha_rio_teste_Centerline at PERMANENT output=teste
>>range=2
>>refline=2
>> main()
>>(Wed Mar 4 17:27:28 2020) Comando terminado (2 segundos)
>>I would like help to try understand whats happening.
>>I would guess that this is a Python 3 vs Python 2 issue. I never
>>updated the
>>addon to Python 3. If someone else can do this, it would be great, as
>>I'm
>>currently on mission abroad and do not really have the necessary
>access
>>to
>>the development tools to do this from here.
>>Moritz
>_______________________________________________
>grass-user mailing list
>https://lists.osgeo.org/mailman/listinfo/grass-user
