[GRASS-user] 7.9.dev: make fails to find default
Rich Shepard
rshepard at appl-ecosys.com
Sun Mar 22 08:57:27 PDT 2020
On Sun, 22 Mar 2020, Markus Neteler wrote:
> ^- this is really written there? Never seen before in 25 years :-)
Markus,
Nope:
GRASS GIS 7.9.dev 88393bbbc compilation log
Started compilation: Sun Mar 22 07:14:46 PDT 2020
Errors in:
/home/rshepard/gis/grass/grass_dev/vector/v.in.pdal
/home/rshepard/gis/grass/grass_dev/scripts/d.correlate
/home/rshepard/gis/grass/grass_dev/scripts/d.frame
/home/rshepard/gis/grass/grass_dev/scripts/d.out.file
/home/rshepard/gis/grass/grass_dev/scripts/d.to.rast
/home/rshepard/gis/grass/grass_dev/scripts/d.polar
/home/rshepard/gis/grass/grass_dev/scripts/d.rast.edit
/home/rshepard/gis/grass/grass_dev/scripts/d.rast.leg
/home/rshepard/gis/grass/grass_dev/scripts/d.redraw
/home/rshepard/gis/grass/grass_dev/scripts/d.shade
/home/rshepard/gis/grass/grass_dev/scripts/d.what.rast
/home/rshepard/gis/grass/grass_dev/scripts/d.what.vect
/home/rshepard/gis/grass/grass_dev/scripts/db.dropcolumn
/home/rshepard/gis/grass/grass_dev/scripts/db.droptable
/home/rshepard/gis/grass/grass_dev/scripts/db.in.ogr
/home/rshepard/gis/grass/grass_dev/scripts/db.out.ogr
/home/rshepard/gis/grass/grass_dev/scripts/db.test
/home/rshepard/gis/grass/grass_dev/scripts/db.univar
/home/rshepard/gis/grass/grass_dev/scripts/g.bands
/home/rshepard/gis/grass/grass_dev/scripts/g.extension
/home/rshepard/gis/grass/grass_dev/scripts/g.extension.all
/home/rshepard/gis/grass/grass_dev/scripts/g.manual
/home/rshepard/gis/grass/grass_dev/scripts/g.search.modules
/home/rshepard/gis/grass/grass_dev/scripts/i.colors.enhance
/home/rshepard/gis/grass/grass_dev/scripts/i.band
/home/rshepard/gis/grass/grass_dev/scripts/i.image.mosaic
/home/rshepard/gis/grass/grass_dev/scripts/i.in.spotvgt
/home/rshepard/gis/grass/grass_dev/scripts/i.oif
/home/rshepard/gis/grass/grass_dev/scripts/i.pansharpen
/home/rshepard/gis/grass/grass_dev/scripts/i.spectral
/home/rshepard/gis/grass/grass_dev/scripts/i.tasscap
/home/rshepard/gis/grass/grass_dev/scripts/m.proj
/home/rshepard/gis/grass/grass_dev/scripts/r.blend
/home/rshepard/gis/grass/grass_dev/scripts/r.buffer.lowmem
/home/rshepard/gis/grass/grass_dev/scripts/r.colors.stddev
/home/rshepard/gis/grass/grass_dev/scripts/r.drain
/home/rshepard/gis/grass/grass_dev/scripts/r.fillnulls
/home/rshepard/gis/grass/grass_dev/scripts/r.grow
/home/rshepard/gis/grass/grass_dev/scripts/r.import
/home/rshepard/gis/grass/grass_dev/scripts/r.in.aster
/home/rshepard/gis/grass/grass_dev/scripts/r.in.srtm
/home/rshepard/gis/grass/grass_dev/scripts/r.in.wms
/home/rshepard/gis/grass/grass_dev/scripts/r.mapcalc.simple
/home/rshepard/gis/grass/grass_dev/scripts/r.mask
/home/rshepard/gis/grass/grass_dev/scripts/r.out.xyz
/home/rshepard/gis/grass/grass_dev/scripts/r.pack
/home/rshepard/gis/grass/grass_dev/scripts/r.plane
/home/rshepard/gis/grass/grass_dev/scripts/r.reclass.area
/home/rshepard/gis/grass/grass_dev/scripts/r.rgb
/home/rshepard/gis/grass/grass_dev/scripts/r.shade
/home/rshepard/gis/grass/grass_dev/scripts/r.tileset
/home/rshepard/gis/grass/grass_dev/scripts/r.unpack
/home/rshepard/gis/grass/grass_dev/scripts/r3.in.xyz
/home/rshepard/gis/grass/grass_dev/scripts/v.build.all
/home/rshepard/gis/grass/grass_dev/scripts/v.centroids
/home/rshepard/gis/grass/grass_dev/scripts/v.clip
/home/rshepard/gis/grass/grass_dev/scripts/v.db.addcolumn
/home/rshepard/gis/grass/grass_dev/scripts/v.db.addtable
/home/rshepard/gis/grass/grass_dev/scripts/v.db.join
/home/rshepard/gis/grass/grass_dev/scripts/v.db.dropcolumn
/home/rshepard/gis/grass/grass_dev/scripts/v.db.droprow
/home/rshepard/gis/grass/grass_dev/scripts/v.db.droptable
/home/rshepard/gis/grass/grass_dev/scripts/v.db.renamecolumn
/home/rshepard/gis/grass/grass_dev/scripts/v.db.reconnect.all
/home/rshepard/gis/grass/grass_dev/scripts/v.db.univar
/home/rshepard/gis/grass/grass_dev/scripts/v.db.update
/home/rshepard/gis/grass/grass_dev/scripts/v.dissolve
/home/rshepard/gis/grass/grass_dev/scripts/v.import
/home/rshepard/gis/grass/grass_dev/scripts/v.in.e00
/home/rshepard/gis/grass/grass_dev/scripts/v.in.geonames
/home/rshepard/gis/grass/grass_dev/scripts/v.in.lines
/home/rshepard/gis/grass/grass_dev/scripts/v.in.mapgen
/home/rshepard/gis/grass/grass_dev/scripts/v.in.wfs
/home/rshepard/gis/grass/grass_dev/scripts/v.rast.stats
/home/rshepard/gis/grass/grass_dev/scripts/v.report
/home/rshepard/gis/grass/grass_dev/scripts/v.pack
/home/rshepard/gis/grass/grass_dev/scripts/v.to.lines
/home/rshepard/gis/grass/grass_dev/scripts/v.unpack
/home/rshepard/gis/grass/grass_dev/scripts/v.what.strds
/home/rshepard/gis/grass/grass_dev/scripts/v.what.vect
/home/rshepard/gis/grass/grass_dev/scripts/wxpyimgview
/home/rshepard/gis/grass/grass_dev/temporal/t.create
/home/rshepard/gis/grass/grass_dev/temporal/t.support
/home/rshepard/gis/grass/grass_dev/temporal/t.topology
/home/rshepard/gis/grass/grass_dev/temporal/t.list
/home/rshepard/gis/grass/grass_dev/temporal/t.info
/home/rshepard/gis/grass/grass_dev/temporal/t.merge
/home/rshepard/gis/grass/grass_dev/temporal/t.remove
/home/rshepard/gis/grass/grass_dev/temporal/t.sample
/home/rshepard/gis/grass/grass_dev/temporal/t.register
/home/rshepard/gis/grass/grass_dev/temporal/t.unregister
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.accumulate
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.accdetect
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.aggregate
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.aggregate.ds
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.colors
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.contour
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.to.rast3
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.univar
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.list
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.mapcalc
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.algebra
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.neighbors
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.series
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.export
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.out.vtk
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.import
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.gapfill
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.extract
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.to.vect
/home/rshepard/gis/grass/grass_dev/temporal/t.rast.what
/home/rshepard/gis/grass/grass_dev/temporal/t.rast3d.list
/home/rshepard/gis/grass/grass_dev/temporal/t.rast3d.extract
/home/rshepard/gis/grass/grass_dev/temporal/t.rast3d.mapcalc
/home/rshepard/gis/grass/grass_dev/temporal/t.rast3d.algebra
/home/rshepard/gis/grass/grass_dev/temporal/t.rast3d.univar
/home/rshepard/gis/grass/grass_dev/temporal/t.rename
/home/rshepard/gis/grass/grass_dev/temporal/t.select
/home/rshepard/gis/grass/grass_dev/temporal/t.snap
/home/rshepard/gis/grass/grass_dev/temporal/t.shift
/home/rshepard/gis/grass/grass_dev/temporal/t.vect.list
/home/rshepard/gis/grass/grass_dev/temporal/t.vect.db.select
/home/rshepard/gis/grass/grass_dev/temporal/t.vect.export
/home/rshepard/gis/grass/grass_dev/temporal/t.vect.extract
/home/rshepard/gis/grass/grass_dev/temporal/t.vect.algebra
/home/rshepard/gis/grass/grass_dev/temporal/t.vect.import
/home/rshepard/gis/grass/grass_dev/temporal/t.vect.what.strds
/home/rshepard/gis/grass/grass_dev/temporal/t.vect.observe.strds
/home/rshepard/gis/grass/grass_dev/temporal/t.vect.univar
/home/rshepard/gis/grass/grass_dev/gui/wxpython/animation
/home/rshepard/gis/grass/grass_dev/gui/wxpython/datacatalog
/home/rshepard/gis/grass/grass_dev/gui/wxpython/mapswipe
/home/rshepard/gis/grass/grass_dev/gui/wxpython/gmodeler
/home/rshepard/gis/grass/grass_dev/gui/wxpython/rlisetup
/home/rshepard/gis/grass/grass_dev/gui/wxpython/psmap
/home/rshepard/gis/grass/grass_dev/gui/wxpython/dbmgr
/home/rshepard/gis/grass/grass_dev/gui/wxpython/vdigit
/home/rshepard/gis/grass/grass_dev/gui/wxpython/iclass
/home/rshepard/gis/grass/grass_dev/gui/wxpython/gcp
/home/rshepard/gis/grass/grass_dev/gui/wxpython/timeline
/home/rshepard/gis/grass/grass_dev/gui/wxpython/tplot
/home/rshepard/gis/grass/grass_dev/gui/wxpython/photo2image
/home/rshepard/gis/grass/grass_dev/gui/wxpython/image2target
In case of errors please change into the directory with error and run 'make'.
If you get multiple errors, you need to deal with them in the order they
appear in the error log. If you get an error building a library, you will
also get errors from anything which uses the library.
Finished compilation: Sun Mar 22 07:22:59 PDT 2020
Rich
