[GRASS-user] 7.9.dev: make fails to find default
Markus Neteler neteler at osgeo.org
Sun Mar 22 08:49:41 PDT 2020
Rich,
On Sun, Mar 22, 2020 at 4:02 PM Rich Shepard <rshepard at appl-ecosys.com> wrote:
> I'm not sure where to look for the source of this error. On
> Slackware-14.2/x86_64:
> GRASS GIS 7.9.dev 88393bbbc compilation log
> Started compilation: Sun Mar 22 07:14:46 PDT 2020
> Errors in:
> <list of all changed files>
^- this is really written there? Never seen before in 25 years :-)
Markus
> In case of errors please change into the directory with error and run 'make'.
> If you get multiple errors, you need to deal with them in the order they
> appear in the error log. If you get an error building a library, you will
> also get errors from anything which uses the library.
> Finished compilation: Sun Mar 22 07:22:59 PDT 2020
> Makefile:57: recipe for target 'default' failed
> make: *** [default] Error 1
> I've had build failures because of libraries or invalid configuration but
> not because a 'default' recipe could not be found. I need a cluestick where
> to put a default target.
> TIA ... and stay healthy,
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
