[GRASS-user] GRASS "shell" plugin + GRASS "Add-ons" in QGIS
Valter Albino
valteralbino at gmail.com
Tue Mar 31 05:45:27 PDT 2020
Hi Vero
*1) *Yes, yes. Because of the activation i can compute the GRASS modules
from this console:
[image: Capturar.JPG]
*2.1) *I 'am using a windows 10 (shame on me) 64 bits OS:
Processador: Intel(R) Core(TM) i5-6600 CPU @ 3.30HHz 3.30 GHz
RAM instalada: 16.0 GB (15.9 GB utilizável)
Placa gráfica: Intel(R) HD Graphics 530 / NVIDIA GeForce GTX 1060 3 GB
HD: 1 TB
*2.2) *With the following QGIS installation:
QGIS version
3.12.1-București
QGIS code revision
121cc00ff0 <https://github.com/qgis/QGIS/commit/121cc00ff0>
Compiled against Qt
5.11.2
Running against Qt
5.11.2
Compiled against GDAL/OGR
3.0.4
Running against GDAL/OGR
3.0.4
Compiled against GEOS
3.8.1-CAPI-1.13.3
Running against GEOS
3.8.1-CAPI-1.13.3
Compiled against SQLite
3.29.0
Running against SQLite
3.29.0
PostgreSQL Client Version
11.5
SpatiaLite Version
4.3.0
QWT Version
6.1.3
QScintilla2 Version
2.10.8
Compiled against PROJ
6.3.1
Running against PROJ
Rel. 6.3.1, February 10th, 2020
OS Version
Windows 10 (10.0)
Active python plugins
CalculateGeometry;
cctv_mapper;
crayfish;
DataPlotly;
dem_slicer;
geocouche-master;
GroupStats;
HCMGIS;
imagefootprint_plugin;
ImportPhotos;
iwams;
LecoS;
lizmap;
midvatten;
mmqgis;
MultiDistanceBuffer;
Multi_Ring_Buffer;
NNJoin;
ntv2_transformations;
processing_whitebox;
profiletool;
qdraw;
qepanet;
QEsg;
qgis2CartTop;
Qgis2threejs;
quick_map_services;
QWater;
rasterstats;
raster_tracer;
rivergis;
SemiAutomaticClassificationPlugin;
splitmultipart;
SwapVectorDirection;
tc_tlag;
tuflow;
valuetool;
WaterNetAnalyzer-master;
db_manager;
MetaSearch;
processing
*3)* GRASS plugin plus QGIS installed with OSGeo4W installer
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
Veronica Andreo <veroandreo gmail.com> escreveu no dia terça, 31/03/2020
à(s) 13:05:
> Hello Valter,
> It works here with a single click. It just opens a new tab there with a
> terminal (bash shell in my case). You first need to open a location and
> mapset with the GRASS Plugin to get it activated, but I think you did,
> right?
> [image: image.png]
> What operative system do you use?
> best,
> Vero
> El mar., 31 mar. 2020 a las 12:53, Valter Albino (<valteralbino gmail.com>)
> escribió:
>> I double click and nothing happens
>> Cumprimentos,
>> Stefan Blumentrath <Stefan.Blumentrath nina.no> escreveu no dia terça,
>> 31/03/2020 à(s) 11:46:
>>> Yes, I think so.
>>> The shell should give you your OS native GRASS command line.
>>> Could you try out and report back?
>>> *From:* grass-user <grass-user-bounces lists.osgeo.org> *On Behalf Of *Valter
>>> Albino
>>> *Sent:* tirsdag 31. mars 2020 12:43
>>> *To:* grass-user <grass-user lists.osgeo.org>
>>> *Subject:* [GRASS-user] GRASS "shell" plugin + GRASS "Add-ons" in QGIS
>>> Good Morning
>>> Sorry for the naivety, but I appreciate any good answers:
>>> - is "GRASS SHELL" in the plugin, in QGIS, usable with double click? Is
>>> he supposed to let you write right?
>>> [image: imagem.png]
>>> - is it possible to use the GRASS "Add-ons" previously installed by
>>> "GRASS GIS" through the QGIS plugin?
>>> Thanks
>>> Cumprimentos,
>>> * Valter Albino - *Geógrafo Físico, M.Sc.
>> grass-user mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/06adb472/attachment-0001.html>
Type: image/png
Desc: não disponível
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/06adb472/attachment-0002.png>
Type: image/png
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/06adb472/attachment-0003.png>
Type: image/jpeg
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/06adb472/attachment-0001.jpe>
