[GRASS-user] GRASS "shell" plugin + GRASS "Add-ons" in QGIS
Valter Albino
valteralbino at gmail.com
Tue Mar 31 07:16:28 PDT 2020
Hi Sajid,
OK, thank you.
In fact, i can only compute "r.mask.rast" and "r.mask.vect"
Cumprimentos,
*Valter Albino -* Geógrafo Físico, M.Sc.
Modelação H&H / Riscos ambientais / OT&U
www.valteralbino.wixsite.com/hydrodynamics
Sajid Pareeth <spareeth gmail.com> escreveu no dia terça, 31/03/2020 à(s)
14:56:
> Dear Valter
> AFAIK, the GRASS shell in QGIS plugin doesnt work in Windows. Somebody
> please correct me, if I am wrong. Also r.mask doesn't work if you use
> grass7 plugin in QGIS.
> As you are using Windows 10, best solution to get the complete command
> line functionalities (as in linux) of GRASS GIS is to follow "Linux Bash
> Shell on Windows 10" (https://itsfoss.com/install-bash-on-windows/),
> which is in-built app with windows 10, you have the option to install
> Ubuntu, Suse linux etc.
> Then you can install GRASS GIS and QGIS in the Linux environment in
> windows 10 and then this plugin works well. You may need a X server
> installed to make gui's work in the Linux environment like xming (
> https://sourceforge.net/projects/xming/ )
> Regards
> Sajid
> On Tue, Mar 31, 2020 at 2:55 PM Valter Albino <valteralbino gmail.com>
> wrote:
>> Another information: the GRASS installation was made with the options
>> marked with "Keep" - see the image bellow:
>> [image: Capturar.JPG]
>> Cumprimentos,
>> Valter Albino <valteralbino gmail.com> escreveu no dia terça, 31/03/2020
>> à(s) 13:45:
>>> Hi Vero
>>> *1) *Yes, yes. Because of the activation i can compute the GRASS
>>> modules from this console:
>>> *2.1) *I 'am using a windows 10 (shame on me) 64 bits OS:
>>> Processador: Intel(R) Core(TM) i5-6600 CPU @ 3.30HHz 3.30 GHz
>>> RAM instalada: 16.0 GB (15.9 GB utilizável)
>>> Placa gráfica: Intel(R) HD Graphics 530 / NVIDIA GeForce GTX 1060 3 GB
>>> HD: 1 TB
>>> *2.2) *With the following QGIS installation:
>>> QGIS version
>>> 3.12.1-București
>>> QGIS code revision
>>> 121cc00ff0 <https://github.com/qgis/QGIS/commit/121cc00ff0>
>>> Compiled against Qt
>>> 5.11.2
>>> Running against Qt
>>> 5.11.2
>>> Compiled against GDAL/OGR
>>> 3.0.4
>>> Running against GDAL/OGR
>>> 3.0.4
>>> Compiled against GEOS
>>> 3.8.1-CAPI-1.13.3
>>> Running against GEOS
>>> 3.8.1-CAPI-1.13.3
>>> Compiled against SQLite
>>> 3.29.0
>>> Running against SQLite
>>> 3.29.0
>>> PostgreSQL Client Version
>>> 11.5
>>> SpatiaLite Version
>>> 4.3.0
>>> QWT Version
>>> 6.1.3
>>> QScintilla2 Version
>>> 2.10.8
>>> Compiled against PROJ
>>> 6.3.1
>>> Running against PROJ
>>> Rel. 6.3.1, February 10th, 2020
>>> OS Version
>>> Windows 10 (10.0)
>>> Active python plugins
>>> CalculateGeometry;
>>> cctv_mapper;
>>> crayfish;
>>> DataPlotly;
>>> dem_slicer;
>>> geocouche-master;
>>> GroupStats;
>>> HCMGIS;
>>> imagefootprint_plugin;
>>> ImportPhotos;
>>> iwams;
>>> LecoS;
>>> lizmap;
>>> midvatten;
>>> mmqgis;
>>> MultiDistanceBuffer;
>>> Multi_Ring_Buffer;
>>> NNJoin;
>>> ntv2_transformations;
>>> processing_whitebox;
>>> profiletool;
>>> qdraw;
>>> qepanet;
>>> QEsg;
>>> qgis2CartTop;
>>> Qgis2threejs;
>>> quick_map_services;
>>> QWater;
>>> rasterstats;
>>> raster_tracer;
>>> rivergis;
>>> SemiAutomaticClassificationPlugin;
>>> splitmultipart;
>>> SwapVectorDirection;
>>> tc_tlag;
>>> tuflow;
>>> valuetool;
>>> WaterNetAnalyzer-master;
>>> db_manager;
>>> MetaSearch;
>>> processing
>>> *3)* GRASS plugin plus QGIS installed with OSGeo4W installer
>>> Cumprimentos,
>>> Veronica Andreo <veroandreo gmail.com> escreveu no dia terça,
>>> 31/03/2020 à(s) 13:05:
>>>> Hello Valter,
>>>> It works here with a single click. It just opens a new tab there with a
>>>> terminal (bash shell in my case). You first need to open a location and
>>>> mapset with the GRASS Plugin to get it activated, but I think you did,
>>>> right?
>>>> [image: image.png]
>>>> What operative system do you use?
>>>> best,
>>>> Vero
>>>> El mar., 31 mar. 2020 a las 12:53, Valter Albino (<
>>>> valteralbino gmail.com>) escribió:
>>>>> I double click and nothing happens
>>>>> Cumprimentos,
>>>>> Stefan Blumentrath <Stefan.Blumentrath nina.no> escreveu no dia
>>>>> terça, 31/03/2020 à(s) 11:46:
>>>>>> Yes, I think so.
>>>>>> The shell should give you your OS native GRASS command line.
>>>>>> Could you try out and report back?
>>>>>> *From:* grass-user <grass-user-bounces lists.osgeo.org> *On Behalf
>>>>>> Of *Valter Albino
>>>>>> *Sent:* tirsdag 31. mars 2020 12:43
>>>>>> *To:* grass-user <grass-user lists.osgeo.org>
>>>>>> *Subject:* [GRASS-user] GRASS "shell" plugin + GRASS "Add-ons" in
>>>>>> QGIS
>>>>>> Good Morning
>>>>>> Sorry for the naivety, but I appreciate any good answers:
>>>>>> - is "GRASS SHELL" in the plugin, in QGIS, usable with double click? Is
>>>>>> he supposed to let you write right?
>>>>>> [image: imagem.png]
>>>>>> - is it possible to use the GRASS "Add-ons" previously installed by
>>>>>> "GRASS GIS" through the QGIS plugin?
>>>>>> Thanks
>>>>>> Cumprimentos,
>>>>>> * Valter Albino - *Geógrafo Físico, M.Sc.
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- próxima parte ----------
Um anexo em HTML foi limpo...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/17ebe3a4/attachment-0001.html>
Type: image/png
Desc: não disponível
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/17ebe3a4/attachment-0002.png>
Type: image/png
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/17ebe3a4/attachment-0003.png>
Type: image/jpeg
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/17ebe3a4/attachment-0002.jpe>
Type: image/jpeg
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/17ebe3a4/attachment-0003.jpe>
