[GRASS-user] GRASS "shell" plugin + GRASS "Add-ons" in QGIS
Sajid Pareeth
spareeth at gmail.com
Tue Mar 31 06:56:41 PDT 2020
Dear Valter
AFAIK, the GRASS shell in QGIS plugin doesnt work in Windows. Somebody
please correct me, if I am wrong. Also r.mask doesn't work if you use
grass7 plugin in QGIS.
As you are using Windows 10, best solution to get the complete command line
functionalities (as in linux) of GRASS GIS is to follow "Linux Bash Shell
on Windows 10" (https://itsfoss.com/install-bash-on-windows/), which is
in-built app with windows 10, you have the option to install Ubuntu, Suse
linux etc.
Then you can install GRASS GIS and QGIS in the Linux environment in windows
10 and then this plugin works well. You may need a X server installed to
make gui's work in the Linux environment like xming (
https://sourceforge.net/projects/xming/ )
Regards
Sajid
On Tue, Mar 31, 2020 at 2:55 PM Valter Albino <valteralbino at gmail.com>
wrote:
> Another information: the GRASS installation was made with the options
> marked with "Keep" - see the image bellow:
> [image: Capturar.JPG]
> Cumprimentos,
> *Valter Albino -* Geógrafo Físico, M.Sc.
> Modelação H&H / Riscos ambientais / OT&U
> www.valteralbino.wixsite.com/hydrodynamics
> Valter Albino <valteralbino at gmail.com> escreveu no dia terça, 31/03/2020
> à(s) 13:45:
>> Hi Vero
>> *1) *Yes, yes. Because of the activation i can compute the GRASS modules
>> from this console:
>> *2.1) *I 'am using a windows 10 (shame on me) 64 bits OS:
>> Processador: Intel(R) Core(TM) i5-6600 CPU @ 3.30HHz 3.30 GHz
>> RAM instalada: 16.0 GB (15.9 GB utilizável)
>> Placa gráfica: Intel(R) HD Graphics 530 / NVIDIA GeForce GTX 1060 3 GB
>> HD: 1 TB
>> *2.2) *With the following QGIS installation:
>> QGIS version
>> 3.12.1-București
>> QGIS code revision
>> 121cc00ff0 <https://github.com/qgis/QGIS/commit/121cc00ff0>
>> Compiled against Qt
>> 5.11.2
>> Running against Qt
>> 5.11.2
>> Compiled against GDAL/OGR
>> 3.0.4
>> Running against GDAL/OGR
>> 3.0.4
>> Compiled against GEOS
>> 3.8.1-CAPI-1.13.3
>> Running against GEOS
>> 3.8.1-CAPI-1.13.3
>> Compiled against SQLite
>> 3.29.0
>> Running against SQLite
>> 3.29.0
>> PostgreSQL Client Version
>> 11.5
>> SpatiaLite Version
>> 4.3.0
>> QWT Version
>> 6.1.3
>> QScintilla2 Version
>> 2.10.8
>> Compiled against PROJ
>> 6.3.1
>> Running against PROJ
>> Rel. 6.3.1, February 10th, 2020
>> OS Version
>> Windows 10 (10.0)
>> Active python plugins
>> CalculateGeometry;
>> cctv_mapper;
>> crayfish;
>> DataPlotly;
>> dem_slicer;
>> geocouche-master;
>> GroupStats;
>> HCMGIS;
>> imagefootprint_plugin;
>> ImportPhotos;
>> iwams;
>> LecoS;
>> lizmap;
>> midvatten;
>> mmqgis;
>> MultiDistanceBuffer;
>> Multi_Ring_Buffer;
>> NNJoin;
>> ntv2_transformations;
>> processing_whitebox;
>> profiletool;
>> qdraw;
>> qepanet;
>> QEsg;
>> qgis2CartTop;
>> Qgis2threejs;
>> quick_map_services;
>> QWater;
>> rasterstats;
>> raster_tracer;
>> rivergis;
>> SemiAutomaticClassificationPlugin;
>> splitmultipart;
>> SwapVectorDirection;
>> tc_tlag;
>> tuflow;
>> valuetool;
>> WaterNetAnalyzer-master;
>> db_manager;
>> MetaSearch;
>> processing
>> *3)* GRASS plugin plus QGIS installed with OSGeo4W installer
>> Cumprimentos,
>> Veronica Andreo <veroandreo at gmail.com> escreveu no dia terça, 31/03/2020
>> à(s) 13:05:
>>> Hello Valter,
>>> It works here with a single click. It just opens a new tab there with a
>>> terminal (bash shell in my case). You first need to open a location and
>>> mapset with the GRASS Plugin to get it activated, but I think you did,
>>> right?
>>> [image: image.png]
>>> What operative system do you use?
>>> best,
>>> Vero
>>> El mar., 31 mar. 2020 a las 12:53, Valter Albino (<
>>> valteralbino at gmail.com>) escribió:
>>>> I double click and nothing happens
>>>> Cumprimentos,
>>>> Stefan Blumentrath <Stefan.Blumentrath at nina.no> escreveu no dia terça,
>>>> 31/03/2020 à(s) 11:46:
>>>>> Yes, I think so.
>>>>> The shell should give you your OS native GRASS command line.
>>>>> Could you try out and report back?
>>>>> *From:* grass-user <grass-user-bounces at lists.osgeo.org> *On Behalf Of
>>>>> *Valter Albino
>>>>> *Sent:* tirsdag 31. mars 2020 12:43
>>>>> *To:* grass-user <grass-user at lists.osgeo.org>
>>>>> *Subject:* [GRASS-user] GRASS "shell" plugin + GRASS "Add-ons" in QGIS
>>>>> Good Morning
>>>>> Sorry for the naivety, but I appreciate any good answers:
>>>>> - is "GRASS SHELL" in the plugin, in QGIS, usable with double click? Is
>>>>> he supposed to let you write right?
>>>>> [image: imagem.png]
>>>>> - is it possible to use the GRASS "Add-ons" previously installed by
>>>>> "GRASS GIS" through the QGIS plugin?
>>>>> Thanks
>>>>> Cumprimentos,
>>>>> * Valter Albino - *Geógrafo Físico, M.Sc.
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/8c882462/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/8c882462/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/8c882462/attachment-0003.png>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/8c882462/attachment-0002.jpe>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/8c882462/attachment-0003.jpe>
