[GRASS-user] fail to, compile on Buster
    Frank David
    frank.david at geophom.fr
    Tue Mar 31 11:28:50 PDT 2020
Hi Markus,
Thank you for your reply.
Unfortunately I have no longer access to this laptop (my colleague is
now at home because covid). But I've not seen error in the the configure
return.
The command was :
CFLAGS="-Wall -Werror-implicit-function-declaration -fno-common -Wextra -Wunused" \
  CXXFLAGS="-Wall"  \
  ./configure \
   --prefix=/usr/local \
   --with-gdal --with-proj --with-proj-share=/usr/share \
   --with-glw --with-nls --with-readline \
   --with-cxx --enable-largefile \
   --with-freetype --with-freetype-includes=/usr/include/freetype2 \
   --with-sqlite --with-cairo --with-python=/usr/bin/python-config \
   --with-wxwidgets --with-geos \
   --with-blas --with-blas-includes=/usr/include/atlas/ \
   --with-lapack --with-lapack-includes=/usr/include/atlas/ \
   --with-netcdf=/usr/bin/nc-config --with-odbc=yes \
   --with-openmp=yes --with-pthread=no --with-postgres=yes \
   --with-postgres-includes=/usr/include/postgresql \
   --with-postgres-libs=/usr/lib/postgresql \
   --with-mysql=yes --with-mysql-includes=/usr/include/mysql
and I also tried the command in INSTALL file, but with the same message.
Anyway, I've installed Grass from Debian Buster repository (7.6), and it's enough for this laptop for the moment (at least until the end of covid crises).
Take care
Regards,
Frank
Le 30/03/2020 à 19:22, Markus Neteler a écrit :
> Hi Frank,
> On Sat, Mar 28, 2020 at 7:54 PM <frank.david at geophom.fr> wrote:
>> Hello,
>> I'm trying to install last release of grass (sources downloaded from
>> github) on a debian 10.3 (Laptop). I've followed the install steps of
>> https://grasswiki.osgeo.org/wiki/Compile_and_Install#GRASS_7_on_Debian_Buster
>> and also from install text file, and I always get :
> can you post your "configure .. " command?
> Do any errors show up?
> Best
> Markus
>> sudo make
>> include/Make/Vars.make:1: include/Make/Platform.make: Aucun fichier ou
>> dossier de ce type
>> make: *** Aucune règle pour fabriquer la cible
>> « include/Make/Platform.make ». Arrêt.
>> I have not seen error in the configure step... Any idea of the problem ?
>> Thanks,
>> Frank
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
-------------- section suivante --------------
Une pièce jointe HTML a été nettoyée...
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200331/7e6eec1d/attachment.html>
