[GRASS-user] Troubles using t.create
Veronica Andreo
veroandreo at gmail.com
Tue May 5 15:44:00 PDT 2020
Hello
I can't reproduce the error with GRASS 7.8.2. No idea what can be the
problem at your end... The parameter `semantictype` is required and not set
in your example... It has a default value though... but maybe worth a try
best,
Vero
El mar., 5 may. 2020 a las 16:01, Worme Florian (SIRS) (<
Florian.Worme at sirs-fr.com>) escribió:
> Hi,
> As I need to work with space time raster data serie, I am trying to use
> the t.create function (the first step to build a strds as indicated in
> tutorials) but unlike other functions that seem to work (I am new to
> GRASS), this one keeps returning errors that my more advanced users
> co-workers and I can't explain.
> *-> Here is an exemple of the error i get when I try it on a local
> computer *
> *(base) fworme at SW-031:~> t.create type=strds temporaltype=absolute \ *
> *> output=precipitation_monthly \ *
> *> title="Monthly precipitation" \ *
> *> description="Dataset with monthly precipitation"*
> *Traceback (most recent call last): *
> * File "/usr/lib64/grass78/scripts/t.create", line 92, in <module> *
> * main() *
> * File "/usr/lib64/grass78/scripts/t.create", line 74, in main *
> * import grass.temporal as tgis *
> * File "/usr/lib64/grass78/etc/python/grass/temporal/__init__.py", line
> 3, in <module> *
> * from .core import * *
> * File "/usr/lib64/grass78/etc/python/grass/temporal/core.py", line 39,
> in <module> *
> * from .c_libraries_interface import * *
> * File
> "/usr/lib64/grass78/etc/python/grass/temporal/c_libraries_interface.py",
> line 20, in <module> *
> * import grass.lib.gis as libgis *
> * File "/usr/lib64/grass78/etc/python/grass/lib/gis.py", line 23, in
> <module> *
> * _libs["grass_gis.7.8"] = load_library("grass_gis.7.8") *
> * File "/usr/lib64/grass78/etc/python/grass/lib/ctypes_loader.py", line
> 64, in load_library *
> * raise ImportError("%s not found." % libname) *
> *ImportError: grass_gis.7.8 not found. *
> *The thing is: finding grass_gis 7.8 shouldn't be a problem, and other
> grass functions are working *
> *-> And here is what I get when I try to run it on
> mundialis/grass-py3-pdal:latest grass - Docker*
> *Starting GRASS GIS... *
> *Creating new GRASS GIS location <tmploc>... *
> *Cleaning up temporary files... *
> *Executing <bash /data/grass.sh> ... (grass.sh containting the same
> exemple I tryed on a local computer) *
> *Default TGIS driver / database set to: *
> *driver: sqlite *
> *database: $GISDBASE/$LOCATION_NAME/$MAPSET/tgis/sqlite.db *
> *WARNING: Temporal database connection defined as: *
> * /tmp/grass7-root-1/tmploc/PERMANENT/tgis/sqlite.db *
> * But database file does not exist. *
> *Creating temporal database: *
> */tmp/grass7-root-1/tmploc/PERMANENT/tgis/sqlite.db *
> * File "/usr/local/grass/scripts/t.create", line 92, in <module> *
> * main() *
> * File "/usr/local/grass/scripts/t.create", line 85, in main *
> * tgis.init() *
> * File "/usr/local/grass/etc/python/grass/temporal/core.py", line 707, in
> init *
> * create_temporal_database(dbif) *
> * File "/usr/local/grass/etc/python/grass/temporal/core.py", line 843, in
> create_temporal_database *
> * self._create_temporal_database_views(dbif) *
> *NameError: name 'self' is not defined *
> *Execution of <bash /data/grass.sh> finished. *
> If anyone has any idea about where does the problem come from...
> Thank you for your help / your time.
> *Ce message et toutes les pièces jointes (ci-après le "message") sont
> établis à l'intention exclusive de ses destinataires et sont confidentiels.
> Si vous recevez ce message par erreur ou s'il ne vous est pas destiné,
> merci de le détruire ainsi que toute copie de votre système et d'en avertir
> immédiatement l'expéditeur. Toute lecture non autorisée, toute utilisation
> de ce message qui n'est pas conforme à sa destination, toute diffusion ou
> toute publication, totale ou partielle, est interdite. L'Internet ne
> permettant pas d'assurer l'intégrité de ce message électronique susceptible
> d'altération, l’expéditeur (et ses filiales) décline(nt) toute
> responsabilité au titre de ce message dans l'hypothèse où il aurait été
> modifié ou falsifié.*
> *This message and any attachments (the "message") is intended solely for
> the intended recipient(s) and is confidential. If you receive this message
> in error, or are not the intended recipient(s), please delete it and any
> copies from your systems and immediately notify the sender. Any
> unauthorized view, use that does not comply with its purpose, dissemination
> or disclosure, either whole or partial, is prohibited. Since the internet
> cannot guarantee the integrity of this message which may not be reliable,
> the sender (and its subsidiaries) shall not be liable for the message if
> modified or falsified. *
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200506/84dd5921/attachment.html>
