[GRASS-user] Troubles using t.create
Anna Petrášová
kratochanna at gmail.com
Fri May 8 05:45:07 PDT 2020
Hi, the second mentioned problem was in master only, but should be fixed
now. Not sure about the first one.
Anna
On Tue, May 5, 2020 at 6:44 PM Veronica Andreo <veroandreo at gmail.com> wrote:
> Hello
> I can't reproduce the error with GRASS 7.8.2. No idea what can be the
> problem at your end... The parameter `semantictype` is required and not set
> in your example... It has a default value though... but maybe worth a try
> best,
> Vero
> El mar., 5 may. 2020 a las 16:01, Worme Florian (SIRS) (<
> Florian.Worme at sirs-fr.com>) escribió:
>> Hi,
>> As I need to work with space time raster data serie, I am trying to use
>> the t.create function (the first step to build a strds as indicated in
>> tutorials) but unlike other functions that seem to work (I am new to
>> GRASS), this one keeps returning errors that my more advanced users
>> co-workers and I can't explain.
>> *-> Here is an exemple of the error i get when I try it on a local
>> computer *
>> *(base) fworme at SW-031:~> t.create type=strds temporaltype=absolute \ *
>> *> output=precipitation_monthly \ *
>> *> title="Monthly precipitation" \ *
>> *> description="Dataset with monthly precipitation"*
>> *Traceback (most recent call last): *
>> * File "/usr/lib64/grass78/scripts/t.create", line 92, in <module> *
>> * main() *
>> * File "/usr/lib64/grass78/scripts/t.create", line 74, in main *
>> * import grass.temporal as tgis *
>> * File "/usr/lib64/grass78/etc/python/grass/temporal/__init__.py", line
>> 3, in <module> *
>> * from .core import * *
>> * File "/usr/lib64/grass78/etc/python/grass/temporal/core.py", line 39,
>> in <module> *
>> * from .c_libraries_interface import * *
>> * File
>> "/usr/lib64/grass78/etc/python/grass/temporal/c_libraries_interface.py",
>> line 20, in <module> *
>> * import grass.lib.gis as libgis *
>> * File "/usr/lib64/grass78/etc/python/grass/lib/gis.py", line 23, in
>> <module> *
>> * _libs["grass_gis.7.8"] = load_library("grass_gis.7.8") *
>> * File "/usr/lib64/grass78/etc/python/grass/lib/ctypes_loader.py", line
>> 64, in load_library *
>> * raise ImportError("%s not found." % libname) *
>> *ImportError: grass_gis.7.8 not found. *
>> *The thing is: finding grass_gis 7.8 shouldn't be a problem, and other
>> grass functions are working *
>> *-> And here is what I get when I try to run it on
>> mundialis/grass-py3-pdal:latest grass - Docker*
>> *Starting GRASS GIS... *
>> *Creating new GRASS GIS location <tmploc>... *
>> *Cleaning up temporary files... *
>> *Executing <bash /data/grass.sh> ... (grass.sh containting the same
>> exemple I tryed on a local computer) *
>> *Default TGIS driver / database set to: *
>> *driver: sqlite *
>> *database: $GISDBASE/$LOCATION_NAME/$MAPSET/tgis/sqlite.db *
>> *WARNING: Temporal database connection defined as: *
>> * /tmp/grass7-root-1/tmploc/PERMANENT/tgis/sqlite.db *
>> * But database file does not exist. *
>> *Creating temporal database: *
>> */tmp/grass7-root-1/tmploc/PERMANENT/tgis/sqlite.db *
>> * File "/usr/local/grass/scripts/t.create", line 92, in <module> *
>> * main() *
>> * File "/usr/local/grass/scripts/t.create", line 85, in main *
>> * tgis.init() *
>> * File "/usr/local/grass/etc/python/grass/temporal/core.py", line 707,
>> in init *
>> * create_temporal_database(dbif) *
>> * File "/usr/local/grass/etc/python/grass/temporal/core.py", line 843,
>> in create_temporal_database *
>> * self._create_temporal_database_views(dbif) *
>> *NameError: name 'self' is not defined *
>> *Execution of <bash /data/grass.sh> finished. *
>> If anyone has any idea about where does the problem come from...
>> Thank you for your help / your time.
>> *Ce message et toutes les pièces jointes (ci-après le "message") sont
>> établis à l'intention exclusive de ses destinataires et sont confidentiels.
>> Si vous recevez ce message par erreur ou s'il ne vous est pas destiné,
>> merci de le détruire ainsi que toute copie de votre système et d'en avertir
>> immédiatement l'expéditeur. Toute lecture non autorisée, toute utilisation
>> de ce message qui n'est pas conforme à sa destination, toute diffusion ou
>> toute publication, totale ou partielle, est interdite. L'Internet ne
>> permettant pas d'assurer l'intégrité de ce message électronique susceptible
>> d'altération, l’expéditeur (et ses filiales) décline(nt) toute
>> responsabilité au titre de ce message dans l'hypothèse où il aurait été
>> modifié ou falsifié.*
>> *This message and any attachments (the "message") is intended solely for
>> the intended recipient(s) and is confidential. If you receive this message
>> in error, or are not the intended recipient(s), please delete it and any
>> copies from your systems and immediately notify the sender. Any
>> unauthorized view, use that does not comply with its purpose, dissemination
>> or disclosure, either whole or partial, is prohibited. Since the internet
>> cannot guarantee the integrity of this message which may not be reliable,
>> the sender (and its subsidiaries) shall not be liable for the message if
>> modified or falsified. *
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20200508/d9d5eeb9/attachment.html>
