[GRASS-user] Status of pdal-2.1 support? [UPDATE]
Maris Nartiss
maris.gis at gmail.com
Mon May 25 22:40:10 PDT 2020
otrd., 2020. g. 26. maijs, plkst. 01:00 — lietotājs Rich Shepard
(<rshepard at appl-ecosys.com>) rakstīja:
> When I run 'make' it eventually fails because,
> v.in.pdal: error while loading shared libraries: libproj.so.15: cannot open
> shared object file: No such file or directory
> That's because proj-7.0.1 provides libproj.so.19.
> Please help me understand.
After upgrading to proj-7 you forgot to recompile all libraries
linking to proj. If you are running a system with pre-built packages,
go bark on your GIS package maintainer.
Be ware — mixing proj 6 and 7 in a single system is a road to failure.
> Regards,
> Rich
Good luck,
Māris.
