[GRASS-user] Status of pdal-2.1 support? [UPDATE]
Rich Shepard
rshepard at appl-ecosys.com
Tue May 26 05:39:56 PDT 2020
On Tue, 26 May 2020, Maris Nartiss wrote:
> After upgrading to proj-7 you forgot to recompile all libraries linking to
> proj. If you are running a system with pre-built packages, go bark on your
> GIS package maintainer.
Māris,
Each time proj, geos, or gdal is upgraded I rebuild the entire stack in that
order. So, when I upgraded to proj7 I rebuilt geos-3.8.1-x86_64-1_SBo and
gdal-3.0.4-x86_64-1_SBo. Is there another library dependent on proj?
> Be ware — mixing proj 6 and 7 in a single system is a road to failure.
$ ls /var/log/packages/ | grep proj
proj-7.0.1-x86_64-1_SBo
When a package is upgraded it replaces the prior one.
Regards,
Rich
