[GRASS-user] Status of pdal-2.1 support? [UPDATE]
Jeff McKenna jmckenna at gatewaygeomatics.com
Tue May 26 05:53:02 PDT 2020
On 2020-05-26 9:39 a.m., Rich Shepard wrote:
> On Tue, 26 May 2020, Maris Nartiss wrote:
>> After upgrading to proj-7 you forgot to recompile all libraries
>> linking to
>> proj. If you are running a system with pre-built packages, go bark on
>> your
>> GIS package maintainer.
> Māris,
> Each time proj, geos, or gdal is upgraded I rebuild the entire stack in
> that
> order. So, when I upgraded to proj7 I rebuilt geos-3.8.1-x86_64-1_SBo and
> gdal-3.0.4-x86_64-1_SBo. Is there another library dependent on proj?
Not sure in terms of GRASS specifically, but keep an eye open for PROJ
required in GeoTIFF and Spatialite libs as well.
-jeff
Jeff McKenna
MapServer Consulting and Training Services
http://gatewaygeo.com/
