[GRASS-user] [GRASS-dev] Bugs in r.stream.extract
Ken Mankoff
mankoff at gmail.com
Tue Nov 24 04:07:04 PST 2020
Hi Ming,
On 2020-11-23 at 09:05 -08, ming han <dustming at gmail.com> wrote...
> Hope this email finds you well. I got a weird result when using
> r.stream.extract, as shown in the following figure. The back grids is
> the flow accumulation layer with a flow accumulation threshold larger
> than 1000. while the blue line is the stream generated by
> r.stream.extract. Why the stream from r.stream.extract did not follow
> flow accumulation results? And how to fix this problem?
Is there any chance you can share the raster that includes this region so I can examine it? And the exact command you ran?
-k.
