[GRASS-user] New Grass start menu
Markus Neteler neteler at osgeo.org
Wed Nov 25 06:55:38 PST 2020
Hi Eric,
Eric Patton <eric.r.patton at protonmail.com> schrieb am Mi., 25. Nov. 2020,
15:50:
> On 20/11/24 10:22PM, Markus Neteler wrote:
> > Hi Eric,
> > On Tue, Nov 24, 2020 at 8:31 PM Eric Patton
> > <eric.r.patton at protonmail.com> wrote:
> > > Hi,
> > > I am using the 2020-11-24 weekly generic Linux build, and I can't seem
> to launch
> > > the start menu using the [--text|--gtext|--gui] flags. When I invoke
> grass79, I
> > > am taken immediately into the last-used Location and Mapset, without
> ever seeing
> > > any start menu. I checked my grassrc, and there doesn't seem to be
> anything
> > > offending in there. I'm running it on Linux Mint 19.3.
> > In case you use Python 3.9 you might be hit by this XML issue
> > https://github.com/OSGeo/grass/issues/1119
> > (just have that here as well).
> > Markus
> Hi Markus, checking I have python3 3.6.9 and wx-config 3.0.4; not sure if
> the
> problem occurs in these versions as well.
No it doesn't.
And a fix has already been submitted by Vaclav :)
So, my problem is unrelated to your's.
Markus
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20201125/70648ef4/attachment.html>
