[GRASS-user] r.param.scale issue
Vincent Bain bain at toraval.fr
Fri Oct 16 09:04:50 PDT 2020
Your remarks Māris are very interesting. I am actually having trouble
with my CPU (AMD Ryzen 7 3800X) and debian stable: I should try to test
several debian backports to have the full temperature sensors support
(not yet supported with 4.19) but am not especially at ease with these
quite dodgy manipulation...
Thank you for your support,
Vincent.
Le vendredi 16 octobre 2020 à 11:39 +0300, Maris Nartiss a écrit :
> Valgrind leak check is needed only for developers as it tracks memory
> consumption not its errors (although in this case it allowed to
> notice
> OpenMP presence by shear luck). As your valgrind run is clean, this
> is
> a dead end.
> On my system I also have a OpenMP and pthreads configuration.
> Unfortunately tracking OpenMP issues is really hard as it might need
> precise thread/process count and timing to reproduce the bug :-(
> Besides it could also be not our bug.
> Please do test carefully your hardware to rule out bad thermal
> management / faulty RAM as your hardware is brand new and thus
> manufacturing defects can not be ruled out yet.
> Also state your CPU and GCC.
> I did not see any problems with Intel(R) Xeon(R) CPU E3-1241 v3 and
> gcc version 9.3.0 (Ubuntu 9.3.0-17ubuntu1~20.04).
> Māris.
> ceturtd., 2020. g. 15. okt., plkst. 11:13 — lietotājs Vincent Bain
> (<bain at toraval.fr>) rakstīja:
> > Thanks Māris for your advice,
> > it sounds dreadful to me to have to deal with these hardware
> > issues...
> > I installed valgrind and ran r.param.scale.
> > Attached are the outputs of the command, first run without any
> > argument, then with --leak-check=full option. Of course it's nearly
> > "doubledutch" to me!
> > Vincent.
