[GRASS-user] Practical examples for t.select
nik at nikosalexandris.net
Thu Apr 15 07:44:21 PDT 2021
Dear all,
would anyone be so kind to provide a simple example with a
`t.rast.algebra` expression that involves
- the if() conditional call and the inverse selection operator, ie.:
{!:,equal}
- if() and {!:,equal,r}
I cannot find a way to build a valid expression that includes both of
these.
The following works:
t.rast.algebra expression='test = if({equal}, A1 >= -30, A2)' base=test
nprocs=40
However, adding the inverse selection operator, won't do:
t.rast.algebra expression='test = if({!:,equal}, A1 >= -30, A2)'
base=test3 nprocs=40 --o
File "/osgeo/grass/dist.x86_64-pc-linux-gnu/scripts/t.rast.algebra",
line 132, in <module>
sys.exit(main())
line 124, in main
pc = p.parse(expression, basename, grass.script.overwrite())
File
"/osgeo/grass/dist.x86_64-pc-linux-gnu/etc/python/grass/temporal/temporal_raster_algebra.py",
line 110, in parse
self.parser.parse(expression)
File
"/home/nik/code/miniconda3/envs/py385/lib/python3.8/site-packages/ply/yacc.py",
line 333, in parse
return self.parseopt_notrack(input, lexer, debug, tracking,
tokenfunc)
File
line 1201, in parseopt_notrack
tok = call_errorfunc(self.errorfunc, errtoken, self)
File
line 192, in call_errorfunc
r = errorfunc(token)
File
"/osgeo/grass/dist.x86_64-pc-linux-gnu/etc/python/grass/temporal/temporal_algebra.py",
line 3042, in p_error
raise SyntaxError("syntax error on line %d, position %i token %s
near '%s' expression '%s'" %
SyntaxError: syntax error on line 1, position 11 token T_SELECT_OPERATOR
near '{!:,equal}' expression 'test = if({!:,equal}, A1 >= -30, A2)'
Even the theoretically equivalent expression (to the first one) won't
do:
→ t.rast.algebra expression='test = if({:,equal}, A1 >= -30, A2)' --o
sys.exit(main())
line 124, in main
File
line 110, in parse
File
line 333, in parse
tokenfunc)
File
File
File
near '{:,equal}' expression 'test3 = if({:,equal}, A1 >= -30, A2)'
