[GRASS-user] v.external, postgis materialized views and projection
Saulteau Don sault.don at gmail.com
Mon Aug 16 12:09:11 PDT 2021
When I use v.external to load a postgis materialized view it says the
projection mismatches the Location but they are actually the same.
% v.external input="PG:host=localhost dbname=database" layer=table_1
output=t
ERROR: Projection of dataset does not appear to match current location.
      Location PROJ_INFO is:
      name: NAD83 / UTM zone 10N
      datum: nad83
      ellps: grs80
      proj: utm
      zone: 10
      no_defs: defined
      init: EPSG:26910
      Dataset PROJ_INFO is:
      name: NAD83 / BC Albers
      datum: nad83
      ellps: grs80
      proj: aea
      lat_0: 45
      lon_0: -126
      lat_1: 50
      lat_2: 58.5
      x_0: 1000000
      y_0: 0
      no_defs: defined
      Difference in: proj
      In case of no significant differences in the projection definitions,
      use the -o flag to ignore them and use current location definition.
      Consider generating a new location from the input dataset using the
      'location' parameter.
It looks like GRASS sees the projection from the source table used for the
materialized view instead of the materialized views projection that was set
in postgis using ST_Transform().
Is this normal for grass to see materialized views like this?
Donovan
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210816/21f63590/attachment.html>
