[GRASS-user] v.rast.stats error: "Unable to seek"
Luí­s Moreira de Sousa luis.de.sousa at protonmail.ch
Mon Feb 1 07:30:09 PST 2021
Hi Micha, thank you for replying.
I recreated the PSU layer in another mapset with the default SQLite back-end, v.rast.stats fails with the exact same error. So this is not related to the back-end.
Below are the outputs you requested. Thank you.
> v.info PSU
| Mapset: MAL |
| Database: /home/duque004/Work/GRASSDATA |
| Title: |
| Map scale: 1:1 |
| Name of creator: duque004 |
| Organization: |
| Source date: Fri Jan 29 08:13:08 2021 |
| Timestamp (first layer): none |
| Map format: native |
| Type of map: vector (level: 2) |
| Number of points: 0 Number of centroids: 19468516 |
| Number of lines: 0 Number of boundaries: 38945853 |
| Number of areas: 19468516 Number of islands: 1 |
| Map is 3D: No |
| Number of dblinks: 1 |
| Projection: unknown |
| N: 4289569.27224353 S: -4452930.72775647 |
| E: 6679312.25515029 W: -2226387.74484971 |
| Digitization threshold: 0 |
| Comment: |
> r.info MAL_Mode_5x5
| Map: MAL_Mode_5x5 Date: Thu Jan 28 09:08:14 2021 |
| Mapset: MAL Login of Creator: duque004 |
| DataBase: /home/duque004/Work/GRASSDATA |
| Title: 5x5 neighborhood: mode of MAL_AFRICA |
| Timestamp: none |
| Type of Map: raster Number of Categories: 0 |
| Data Type: CELL |
| Rows: 87425 |
| Columns: 89057 |
| Total Cells: 7785808225 |
| N: 4289569.27224353 S: -4452930.72775647 Res: 100 |
| E: 6679312.25515029 W: -2226387.74484971 Res: 100 |
| Range of data: min = 0 max = 1 |
| Data Description: |
| generated by r.neighbors |
| Comments: |
| r.neighbors input="MAL_AFRICA" output="MAL_Mode_5x5" method="mode" s\ |
| ize=5 |
Luís
Sent with [ProtonMail](https://protonmail.com) Secure Email.
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Friday, January 29, 2021 3:31 PM, Micha Silver <tsvibar at gmail.com> wrote:
> On Fri, Jan 29, 2021 at 3:53 PM Luí­s Moreira de Sousa via grass-user <grass-user at lists.osgeo.org> wrote:
>> Dear all,
>> I am getting the error "Unable to seek" with v.stats.error. There is not much information that could point the cause, just a warning saying that some data base files are not found. I checked the database connection and everything looks in order (see below). Any hints on what may be causing this error?
>> Thank you.
>>> v.rast.stats map=PSU raster=MAL_Mode_5x5 method=number column_prefix=mal
>> ERROR: Unable to seek: Invalid argument
>> ERROR: An error occurred while converting vector to raster
>> WARNING: No data base element files found
>>> db.connect -p
>> driver: pg
>> database: s4a
>> schema: mal
>> group:
>>> psql -d s4a -p 5434
>> psql (12.5 (Ubuntu 12.5-0ubuntu0.20.04.1))
>> Type "help" for help.
>> s4a=# \dt mal.*
>> List of relations
>> Schema | Name | Type | Owner
>> mal | psu | table | duque004
>> (1 rows)
> Could it be simply CAPS in the vector name vs small letters in the Postgres table?
> Can you post the outputs from:
> v.info PSU
> r.info MAL_Mode_5x5
>> s4a=# select count(*) from mal.psu;
>> count
>> 19468516
>> (1 row)
>> Luís
>> grass-user mailing list
>> https://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silver
> Ben Gurion Univ
> Sde-Boker Remote Sensing Lab
> cell: +972 (52) 3665918
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210201/1ea90609/attachment-0001.html>
