[GRASS-user] v.rast.stats error: "Unable to seek"
    Micha Silver
    tsvibar at gmail.com
    Mon Feb  1 12:32:00 PST 2021
Hi Luis:
On 2/1/21 5:30 PM, Luí s Moreira de Sousa wrote:
> Hi Micha, thank you for replying.
> I recreated the PSU layer in another mapset with the default SQLite
> back-end, v.rast.stats fails with the exact same error. So this is not
> related to the back-end.
> Below are the outputs you requested. Thank you.
> > v.info PSU
> | Mapset: MAL                                                       |
> | Location: S4AHomolosine                                             |
> | Database: /home/duque004/Work/GRASSDATA                             |
> | Title: |
> | Map scale: 1:1                                                       |
> | Name of creator:
> duque004                                                  |
> | Organization: |
> | Source date:     Fri Jan 29 08:13:08
> 2021                                  |
> | Timestamp (first layer):
> none                                              |
> | Map format: native                                                    |
> |   Type of map: vector (level:
> 2)                                           |
> |   Number of points:       0               Number of centroids:
> 19468516   |
> |   Number of lines:        0               Number of boundaries:
> 38945853   |
> |   Number of areas:        19468516        Number of islands:
> 1          |
> |   Map is 3D: No                                               |
> |   Number of dblinks: 1                                                |
> |   Projection:
> unknown                                                      |
> |               N:  4289569.27224353    S:
> -4452930.72775647                 |
> |               E:  6679312.25515029    W:
> -2226387.74484971                 |
> |   Digitization threshold:
> 0                                                |
> | Comment: |
> > r.info MAL_Mode_5x5
> | Map:      MAL_Mode_5x5                   Date: Thu Jan 28 09:08:14
> 2021    |
> | Mapset:   MAL                            Login of Creator:
> duque004        |
> | DataBase: /home/duque004/Work/GRASSDATA |
> | Title:    5x5 neighborhood: mode of
> MAL_AFRICA                             |
> | Timestamp: none |
> |   Type of Map:  raster               Number of Categories:
> 0               |
> |   Data Type:
> CELL                                                       |
> |   Rows: 87425                                                      |
> |   Columns: 89057                                                      |
> |   Total Cells:
> 7785808225                                                 |
> |        Projection:
> unknown                                                 |
> |            N: 4289569.27224353    S: -4452930.72775647 Res:
> 100        |
> |            E: 6679312.25515029    W: -2226387.74484971 Res:
> 100        |
> |   Range of data:    min = 0  max =
> 1                                       |
> |   Data Description: |
> |    generated by
> r.neighbors                                                |
> | Comments: |
> |    r.neighbors input="MAL_AFRICA" output="MAL_Mode_5x5"
> method="mode" s\   |
> | ize=5 |
So the vector contains about 20 million polygons, and the raster about 8
billion cells. (~=32GB ?)
Does you computer have enough muscle for this?
> Luís
> Sent with ProtonMail <https://protonmail.com> Secure Email.
> ‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
> On Friday, January 29, 2021 3:31 PM, Micha Silver <tsvibar at gmail.com>
> wrote:
>> On Fri, Jan 29, 2021 at 3:53 PM Luís Moreira de Sousa via grass-user
>> <grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>> wrote:
>>     Dear all,
>>     I am getting the error "Unable to seek" with v.stats.error. There
>>     is not much information that could point the cause, just a
>>     warning saying that some data base files are not found. I checked
>>     the database connection and everything looks in order (see
>>     below). Any hints on what may be causing this error?
>>     Thank you.
>>     > v.rast.stats map=PSU raster=MAL_Mode_5x5 method=number
>>     column_prefix=mal
>>     ERROR: Unable to seek: Invalid argument
>>     ERROR: An error occurred while converting vector to raster
>>     WARNING: No data base element files found
>>     > db.connect -p
>>     driver: pg
>>     database: s4a
>>     schema: mal
>>     group:
>>     > psql -d s4a -p 5434
>>     psql (12.5 (Ubuntu 12.5-0ubuntu0.20.04.1))
>>     Type "help" for help.
>>     s4a=# \dt mal.*
>>                       List of relations
>>     Schema |           Name           | Type  |  Owner
>>     mal    | psu                      | table | duque004
>>     (1 rows)
>> Could it be simply CAPS in the vector name vs small letters in the
>> Postgres table?
>> Can you post the outputs from:
>> v.info <http://v.info> PSU
>> r.info <http://r.info> MAL_Mode_5x5
>>     s4a=# select count(*) from mal.psu;
>>       count
>>     19468516
>>     (1 row)
>>     Luís
>>     _______________________________________________
>>     grass-user mailing list
>>     https://lists.osgeo.org/mailman/listinfo/grass-user
>>     <https://lists.osgeo.org/mailman/listinfo/grass-user>
>> Micha Silver
>> Ben Gurion Univ
>> Sde-Boker Remote Sensing Lab
>> cell: +972 (52) 3665918
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
https://orcid.org/0000-0002-1128-1325
