[GRASS-user] Error launching GUI in latest verison of trunk
    Eric Patton
    eric.r.patton at protonmail.com
    Sun Feb  7 14:20:13 PST 2021
I forget if these kind of errors should go to the dev list or the user's list, it's been so long since I've been on dev.
Anyway, I get the following error launching the GUI after updating my git repo to Feb. 7th:
Details: <free(): invalid pointer
File "/home/epatton/.grass7/addons/scripts/r.mblend", line 281, in <module>
gscript.use_temp_region()
File "/usr/local/grass79/etc/python/grass/script/core.py", line 1285, in use_temp_region
run_command("g.region", flags="u", save=name, overwrite=True)
File "/usr/local/grass79/etc/python/grass/script/core.py", line 501, in run_command
return handle_errors(returncode, result=None, args=args, kwargs=kwargs)
File "/usr/local/grass79/etc/python/grass/script/core.py", line 393, in handle_errors
raise CalledModuleError(module=module, code=code,
grass.exceptions.CalledModuleError: Module run g.region g.region --o -u save=tmp.r.mblend.265507 ended with error
Process ended with non-zero return code -6. See errors in the (error) output.
This is Grass 7.9 on Linux Mint 20.1.
Eric Patton
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210207/905bbe2e/attachment.html>
