[GRASS-user] r.futures.demand
Mitchell Meads
mitchell.meads at tamu.edu
Thu Feb 11 12:14:20 PST 2021
Hi Anna,
Thank you for the helpful information! I suppose I was somewhat confused as
to what exactly should all be in the parameters for the r.futures.potential
submodel. I've made the changes you've suggested above, but I'm still
getting some type of "Unable to select cursor" error. Below is the command
output with its errors, if you could help me pin down what I'm doing wrong,
that would be great! Also on a side note, unfortunately, I'm not
experienced in R and and somewhat relying on the futures modeling in GRASS
to complete my task. Thanks again for your help!
(Thu Feb 11 13:11:21 2021)
r.futures.potential --overwrite input=sampling_f_km at PERMANENT
output=potential_f_km.csv
columns=devclip_2016,block_rast,county_rast,devpress_0_5_2016,dist_to_evac_km,dist_to_pp_km,dist_toh20_2001_km,dist_toh20_2004_km,dist_toh20_2006,dist_toh20_2008_km,dist_toh20_2011_km,dist_toh20_2013_km,dist_toh20_2016_km,per_forest_2001,per_forest_2004,per_forest_2006,per_forest_2008,per_forest_2011,per_forest_2013,per_forest_2016,urban_change_01_16
developed_column=devclip_2016 subregions_column=county_rast min_variables=5
max_variables=10
Computing model...
WARNING: fixed-effect model matrix is rank deficient so dropping 2 columns
/ coefficients
Error in pwrssUpdate(pp, resp, tol = tolPwrss, GQmat = GQmat, compDev =
compDev, :
pwrssUpdate did not converge in (maxit) iterations
Calls: glmer ... <Anonymous> -> <Anonymous> -> stopifnot -> fn ->
pwrssUpdate
In addition: Warning message:
Some predictor variables are on very different scales: consider rescaling
Execution halted
/ coefficients
compDev, :
pwrssUpdate
Execution halted
ERROR: Running R script failed, check messages above
(Thu Feb 11 13:11:25 2021) Command finished (3 sec)
(Thu Feb 11 14:09:43 2021)
r.futures.potential -d --overwrite input=sampling_f_km at PERMANENT
columns=devclip_2016,devpress_0_5_2016,dist_to_evac_km,dist_to_pp_km,dist_toh20_2016_km,per_forest_2016,
developed_column=urban_change_01_16 subregions_column=county_rast
min_variables=2 max_variables=6
DBMI-SQLite driver error:
Error in sqlite3_prepare():
SELECT devclip_2016,devpress_0_5_2016,dist_to_evac_km,dist_t
o_pp_km,dist_toh20_2016_km,per_forest_2016,,urban_change_01_
16,county_rast FROM sampling_f_km WHERE devclip_2016 IS NOT
NULL AND devpress_0_5_2016 IS NOT NULL AND dist_to_evac_km
IS NOT NULL AND dist_to_pp_km IS NOT NULL AND
dist_toh20_2016_km IS NOT NULL AND per_forest_2016 IS NOT
NULL AND IS NOT NULL AND urban_change_01_16 IS NOT NULL AND
county_rast IS NOT NULL
near ",": syntax error
ERROR: Unable to open select cursor
File "/Users/mitchellmeads/Library/GRASS/7.8/Modules/scrip
ts/r.futures.potential", line 221, in <module>
sys.exit(main())
ts/r.futures.potential", line 181, in main
gscript.run_command('v.db.select', map=vinput,
columns=columns, separator='comma', where=where,
file=TMP_CSV)
File "/Applications/GRASS-7.8.app/Contents/Resources/etc/p
ython/grass/script/core.py", line 441, in run_command
return handle_errors(returncode, returncode, args,
kwargs)
ython/grass/script/core.py", line 342, in handle_errors
raise CalledModuleError(module=None, code=code,
grass.exceptions.CalledModuleError: Module run None
v.db.select map=sampling_f_km at PERMANENT columns=devclip_2016
2016_km,per_forest_2016,,urban_change_01_16,county_rast
separator=comma where=devclip_2016 IS NOT NULL AND
devpress_0_5_2016 IS NOT NULL AND dist_to_evac_km IS NOT
NULL AND dist_to_pp_km IS NOT NULL AND dist_toh20_2016_km IS
NOT NULL AND per_forest_2016 IS NOT NULL AND IS NOT NULL
AND urban_change_01_16 IS NOT NULL AND county_rast IS NOT
NULL file=/Volumes/Extreme
SSD/grassdata/forecast2/PERMANENT/.tmp/Mitchells-MacBook-
Pro.local/49600.0.csv ended with error
Process ended with non-zero return code 1. See errors in the
(error) output.
(Thu Feb 11 14:09:44 2021) Command finished (0 sec)
Cheers,
Mitchell Meads, PhD Student
Texas A&M University at Galveston
Marine & Coastal Management Sciences; CTBS <http://www.tamug.edu/ctbs/>
Email: mitchell.meads at tamu.edu
On Thu, Feb 11, 2021 at 2:01 PM Anna Petrášová <kratochanna at gmail.com>
wrote:
> Hi Mitchell,
> looking at your command there are several things to fix. Parameter columns
> should have only the predictors, so for example remove county_rast and
> urban_change_01_16. Parameter developed_column should be the response
> variable, so I suppose urban_change_01_16 is the one to use here. Lastly,
> without the dredge mode only use combination of predictors that are not
> correlated and don't represent the same info, for example, do not include
> since these all represent the same variable (I suppose). Without the dredge
> mode, all provided predictors will be used in the model, with the dredge
> mode, it will try different combinations and return the best model.
> Note r.futures.potential is basically just a wrapper around R glmer (lme4)
> function, so if you are familiar with R, you can experiment with finding a
> model directly in R if you need more flexibility etc.
> Please keep the conversation on this mailing list which is archived, so
> that others can add to it or benefit from it later.
> Best,
> Anna
> On Thu, Feb 11, 2021 at 2:12 PM Mitchell Meads <mitchell.meads at tamu.edu>
> wrote:
>> Hi Anna,
>> I've revisited the r.futures.potential submodel for the futures modeling
>> and I still can't get the r.futures.potential submodel to run. I've
>> rescaled my variables so they all should be on a similar scale but the
>> program is telling me that the variables are still not in appropriate scale
>> along with some other error messages that I have copied below. Please let
>> me know what you think I'm doing wrong.
>> max_variables=10
>> Computing model...
>> columns / coefficients
>> compDev, :
>> pwrssUpdate
>> Execution halted
>> compDev, :
>> pwrssUpdate
>> Execution halted
>> Cheers,
>> On Sat, Jan 23, 2021 at 9:54 PM Anna Petrášová <kratochanna at gmail.com>
>> wrote:
>>> Hi Mitchell,
>>> On Fri, Jan 22, 2021 at 3:23 PM Mitchell Meads <mitchell.meads at tamu.edu>
>>> wrote:
>>>> Hi all,
>>>> I'm getting an error when running r.futures.demand that says "Number of
>>>> development raster maps doesn't not correspond to the number of observed
>>>> times". I thought that a fix for this would be to make sure my input
>>>> population csv had years that matched the input raster maps in the first
>>>> column but this didn't change the error. If you could let me know what you
>>>> think I'm doing wrong, that would be greatly appreciated!
>>> The error means the number of raster maps in the development parameter
>>> does not match the number of years in the observed_population CSV. So for
>>> example, if you specify development=urban_2001,urban_2006,urban_2011 (3
>>> maps) then the observed_population file should look like this (header + 3
>>> lines):
>>> year,37037,37063,...
>>> 2001,19860,10980,...
>>> 2006,20760,12660,...
>>> 2011,21070,13090,...
>>> If you can't see any obvious mistake with your data, I would have to see
>>> the r.futures.demand command you are trying to execute and the input CSV
>>> file.
>>>> Cheers,
>>>> Mitchell
>>>> _______________________________________________
>>>> grass-user mailing list
>>>> grass-user at lists.osgeo.org
>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
>>>> <https://urldefense.com/v3/__https://lists.osgeo.org/mailman/listinfo/grass-user__;!!KwNVnqRv!S-XTr0kWrbJ704p6CIighh6PUpDBJchKEjSQMopVh0bXjHxBYSqNzjaTNlgopVQ1ulKp$>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210211/6eb7c893/attachment-0001.html>
