[GRASS-user] r.futures.demand
Anna Petrášová kratochanna at gmail.com
Thu Feb 11 19:59:46 PST 2021
On Thu, Feb 11, 2021 at 3:14 PM Mitchell Meads <mitchell.meads at tamu.edu>
wrote:
> Hi Anna,
> Thank you for the helpful information! I suppose I was somewhat confused
> as to what exactly should all be in the parameters for the
> r.futures.potential submodel. I've made the changes you've suggested above,
> but I'm still getting some type of "Unable to select cursor" error. Below
> is the command output with its errors, if you could help me pin down what
> I'm doing wrong, that would be great! Also on a side note, unfortunately,
> I'm not experienced in R and and somewhat relying on the futures modeling
> in GRASS to complete my task. Thanks again for your help!
> (Thu Feb 11 13:11:21 2021)
> r.futures.potential --overwrite input=sampling_f_km at PERMANENT
> output=potential_f_km.csv
> columns=devclip_2016,block_rast,county_rast,devpress_0_5_2016,dist_to_evac_km,dist_to_pp_km,dist_toh20_2001_km,dist_toh20_2004_km,dist_toh20_2006,dist_toh20_2008_km,dist_toh20_2011_km,dist_toh20_2013_km,dist_toh20_2016_km,per_forest_2001,per_forest_2004,per_forest_2006,per_forest_2008,per_forest_2011,per_forest_2013,per_forest_2016,urban_change_01_16
> developed_column=devclip_2016 subregions_column=county_rast min_variables=5
> max_variables=10
> Computing model...
> WARNING: fixed-effect model matrix is rank deficient so dropping 2 columns
> / coefficients
> Error in pwrssUpdate(pp, resp, tol = tolPwrss, GQmat = GQmat, compDev =
> compDev,  :
> pwrssUpdate did not converge in (maxit) iterations
> Calls: glmer ... <Anonymous> -> <Anonymous> -> stopifnot -> fn ->
> pwrssUpdate
> In addition: Warning message:
> Some predictor variables are on very different scales: consider rescaling
> Execution halted
> / coefficients
> compDev,  :
> pwrssUpdate
> Execution halted
> ERROR: Running R script failed, check messages above
> (Thu Feb 11 13:11:25 2021) Command finished (3 sec)
> (Thu Feb 11 14:09:43 2021)
> r.futures.potential -d --overwrite input=sampling_f_km at PERMANENT
> columns=devclip_2016,devpress_0_5_2016,dist_to_evac_km,dist_to_pp_km,dist_toh20_2016_km,per_forest_2016,
looks like you have an extra comma after per_forest_2016? What
is devclip_2016?
> developed_column=urban_change_01_16 subregions_column=county_rast
> min_variables=2 max_variables=6
> DBMI-SQLite driver error:
> Error in sqlite3_prepare():
> SELECT devclip_2016,devpress_0_5_2016,dist_to_evac_km,dist_t
> o_pp_km,dist_toh20_2016_km,per_forest_2016,,urban_change_01_
> 16,county_rast FROM sampling_f_km WHERE devclip_2016 IS NOT
> NULL AND devpress_0_5_2016 IS NOT NULL AND dist_to_evac_km
> IS NOT NULL AND dist_to_pp_km IS NOT NULL AND
> dist_toh20_2016_km IS NOT NULL AND per_forest_2016 IS NOT
> NULL AND  IS NOT NULL AND urban_change_01_16 IS NOT NULL AND
> county_rast IS NOT NULL
> near ",": syntax error
> ERROR: Unable to open select cursor
> Traceback (most recent call last):
>   File "/Users/mitchellmeads/Library/GRASS/7.8/Modules/scrip
> ts/r.futures.potential", line 221, in <module>
>     sys.exit(main())
> ts/r.futures.potential", line 181, in main
>     gscript.run_command('v.db.select', map=vinput,
> columns=columns, separator='comma', where=where,
> file=TMP_CSV)
>   File "/Applications/GRASS-7.8.app/Contents/Resources/etc/p
> ython/grass/script/core.py", line 441, in run_command
>     return handle_errors(returncode, returncode, args,
> kwargs)
> ython/grass/script/core.py", line 342, in handle_errors
>     raise CalledModuleError(module=None, code=code,
> grass.exceptions.CalledModuleError: Module run None
> v.db.select map=sampling_f_km at PERMANENT columns=devclip_2016
> 2016_km,per_forest_2016,,urban_change_01_16,county_rast
> separator=comma where=devclip_2016 IS NOT NULL AND
> devpress_0_5_2016 IS NOT NULL AND dist_to_evac_km IS NOT
> NULL AND dist_to_pp_km IS NOT NULL AND dist_toh20_2016_km IS
> NOT NULL AND per_forest_2016 IS NOT NULL AND  IS NOT NULL
> AND urban_change_01_16 IS NOT NULL AND county_rast IS NOT
> NULL file=/Volumes/Extreme
> SSD/grassdata/forecast2/PERMANENT/.tmp/Mitchells-MacBook-
> Pro.local/49600.0.csv ended with error
> Process ended with non-zero return code 1. See errors in the
> (error) output.
> (Thu Feb 11 14:09:44 2021) Command finished (0 sec)
> Cheers,
> Mitchell Meads, PhD Student
> Texas A&M University at Galveston
> Marine & Coastal Management Sciences; CTBS <http://www.tamug.edu/ctbs/>
> Email: mitchell.meads at tamu.edu
> On Thu, Feb 11, 2021 at 2:01 PM Anna Petrášová <kratochanna at gmail.com>
> wrote:
>> Hi Mitchell,
>> looking at your command there are several things to fix. Parameter
>> columns should have only the predictors, so for example remove county_rast
>> and urban_change_01_16. Parameter developed_column should be the response
>> variable, so I suppose urban_change_01_16 is the one to use here. Lastly,
>> without the dredge mode only use combination of predictors that are not
>> correlated and don't represent the same info, for example, do not include
>> since these all represent the same variable (I suppose). Without the dredge
>> mode, all provided predictors will be used in the model, with the dredge
>> mode, it will try different combinations and return the best model.
>> Note r.futures.potential is basically just a wrapper around R glmer
>> (lme4) function, so if you are familiar with R, you can experiment with
>> finding a model directly in R if you need more flexibility etc.
>> Please keep the conversation on this mailing list which is archived, so
>> that others can add to it or benefit from it later.
>> Best,
>> Anna
>> On Thu, Feb 11, 2021 at 2:12 PM Mitchell Meads <mitchell.meads at tamu.edu>
>> wrote:
>>> Hi Anna,
>>> I've revisited the r.futures.potential submodel for the futures modeling
>>> and I still can't get the r.futures.potential submodel to run. I've
>>> rescaled my variables so they all should be on a similar scale but the
>>> program is telling me that the variables are still not in appropriate scale
>>> along with some other error messages that I have copied below. Please let
>>> me know what you think I'm doing wrong.
>>> max_variables=10
>>> Computing model...
>>> columns / coefficients
>>> compDev,  :
>>> pwrssUpdate
>>> Execution halted
>>> compDev,  :
>>> pwrssUpdate
>>> Execution halted
>>> Cheers,
>>> On Sat, Jan 23, 2021 at 9:54 PM Anna Petrášová <kratochanna at gmail.com>
>>> wrote:
>>>> Hi Mitchell,
>>>> On Fri, Jan 22, 2021 at 3:23 PM Mitchell Meads <mitchell.meads at tamu.edu>
>>>> wrote:
>>>>> Hi all,
>>>>> I'm getting an error when running r.futures.demand that says "Number
>>>>> of development raster maps doesn't not correspond to the number of observed
>>>>> times". I thought that a fix for this would be to make sure my input
>>>>> population csv had years that matched the input raster maps in the first
>>>>> column but this didn't change the error. If you could let me know what you
>>>>> think I'm doing wrong, that would be greatly appreciated!
>>>> The error means the number of raster maps in the development parameter
>>>> does not match the number of years in the observed_population CSV. So for
>>>> example, if you specify development=urban_2001,urban_2006,urban_2011 (3
>>>> maps) then the observed_population file should look like this (header + 3
>>>> lines):
>>>> year,37037,37063,...
>>>> 2001,19860,10980,...
>>>> 2006,20760,12660,...
>>>> 2011,21070,13090,...
>>>> If you can't see any obvious mistake with your data, I would have to
>>>> see the r.futures.demand command you are trying to execute and the input
>>>> CSV file.
>>>>> Cheers,
>>>>> Mitchell
>>>>> _______________________________________________
>>>>> grass-user mailing list
>>>>> grass-user at lists.osgeo.org
>>>>> https://lists.osgeo.org/mailman/listinfo/grass-user
>>>>> <https://urldefense.com/v3/__https://lists.osgeo.org/mailman/listinfo/grass-user__;!!KwNVnqRv!S-XTr0kWrbJ704p6CIighh6PUpDBJchKEjSQMopVh0bXjHxBYSqNzjaTNlgopVQ1ulKp$>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210211/cca9fe67/attachment-0001.html>
