[GRASS-user] Creating a png file with multiple vector maps
Chris Bartolomei
surfcjb at yahoo.com
Wed Feb 17 10:17:59 PST 2021
Good afternoon Moritz - thank you for the feedback :)I've been able to get GRASS 7.8 running with msys on my pc so I can send images etc. now... I tried repeating what I had done at work and I have the same results ... I also downloaded the Spearfish dataset as you suggested and brought in the boundary_county vector. I can go into Properties and fill color orange and outline gray, but I go to the console and do the d.vect map=boundary_county color=red fill_color=orange and all I get is the red boundaries.I attached an image of everything ... the Layer Manager, the Display window, the msys console window with my commands run and all my exported GRASS variables, and the resultant png image.I've tried this with several other polygon vector files and I get the same darn thing. Can you see anything wrong with my variable settings ?
GRASS 7.8.4> v.info -t boundary_county at WarningPoints #from the Spearfish dataset
nodes=1114
points=0
lines=0
boundaries=1910
centroids=926
areas=926
islands=130
primitives=2836
map3d=0
GRASS 7.8.4> env | grep GRASS
MANPATH=C:\OSGEO4~1\apps\grass\grass78\docs\man;C:\Users\Chris\AppData\Roaming\GRASS7\addons\docs\man
GRASS_PYTHON=C:\OSGEO4~1\bin\python3.exe
GRASS_RENDER_TRANSPARENCY=true
GRASS_PAGER=more
GRASS_GNUPLOT=gnuplot -persist
GRASS_RENDER_PNG_COMPRESSION=0
GRASS_RENDER_FILE_COMPRESSION=0
GRASSBIN=C:\OSGEO4~1\apps\grass\grass78\bin
GRASS_SH=C:\OSGEO4~1\apps\msys\bin\sh.exe
GRASS_RENDER_HEIGHT=480
PATH=/c/OSGEO4~1/apps/grass/grass78/lib:/c/OSGEO4~1/apps/grass/grass78/bin:/c/Users/Chris/AppData/Roaming/GRASS7/addons/bin:/c/OSGEO4~1/apps/Python37:/c/OSGEO4~1/apps/Python37/Scripts:/c/OSGEO4~1/apps/Python27/Scripts:/c/OSGEO4~1/bin:/c/WINDOWS/system32:/c/WINDOWS:/c/WINDOWS/system32/WBem:/usr/bin:/c/Program Files/RStudio/bin:/c/OSGEO4~1/apps/grass/grass78/bin:/c/OSGEO4~1/apps/grass/grass78/scripts:/c/OSGEO4~1/apps/grass/grass78/lib:.:/c/OSGEO4~1/apps/Python37/lib/site-packages/pywin32_system32
GRASS_MESSAGE_FORMAT=plain
GRASS_PROJSHARE=C:\OSGEO4~1\share\proj
PS1=GRASS 7.8.4>
GRASS_VERSION=7.8.4
GRASS_HTML_BROWSER=start
GRASS_RENDER_WIDTH=640
GRASS_RENDER_TRUECOLOR=true
GRASS_RENDER_IMMEDIATE=png
GRASS_ADDON_BASE=C:\Users\Chris\AppData\Roaming\GRASS7\addonsGRASS_RENDER_FILE_READ=true
GRASS 7.8.4> d.vect map=boundary_county at WarningPoints color=red fill_color=orange
d.vect complete.
GRASS 7.8.4>
Thanks again ... and sorry to bother you so much!:)
Chris
On Wednesday, February 17, 2021, 7:57:08 AM EST, Moritz Lennert <mlennert at club.worldonline.be> wrote:
Hi Chris,
On 17/02/21 02:30, Chris Bartolomei wrote:
> Ohhhhh !! Sooooooo close ! I can get the two vector maps to overlay and
> display but no matter what I do I cannot get them to do a color fill ...
> ugh ... fill_color does nothing. I can use "d.vect map=admin_area
> color=red" and the boundaries change to red, but "d.vect map=admin_area
> color=black fill_color=red" and i do not get any filled color. So
> frustrating. I thought maybe my shapefile imported as just a boundary
> but when I do a "v.category input=admin_area option=report" I get:
> Layer/table 1/admin_area
> type count min max
> point 0 0 0
> line 0 0 0
> boundary 0 0 0
> centroid 59 1 25
> area 0 0 0
> face 0 0 0
> kernel 0 0 0
> all 59 1 25
> Should I have areas in there too ??
I'm not really sure what 'area' in the output of v.category actually
refers to, as areas cannot have categories in GRASS GIS.
In order to see if you have areas in your file, check with v.info:
> I wonder if the import went wonky.... what is strange is that the ps.map
> tool fills the polygons just fine.
> Moritz - could please I ask you to do a v.category on one of your vector
> maps (v.category input=censuslbk_wwake at PERMANENT option=report) and see
> if it has areas in it or just centroids like I have?
GRASS 7.8.5 (nc_spm_08_grass7):~ > v.info -t boundary_county
nodes=1114
points=0
lines=0
boundaries=1910
centroids=926
areas=926
islands=130
primitives=2836
map3d=0
but
>v.category boundary_county op=report
Layer/table: 1/boundary_county
type count min max
point 0 0 0
line 0 0 0
boundary 0 0 0
centroid 926 1 926
area 0 0 0
face 0 0 0
kernel 0 0 0
all 926 1 926
In order to find out if the issue comes from your data or from your
installation of GRASS GIS, you can also download the NC demo data set
from https://grass.osgeo.org/download/data/#NorthCarolinaDataset and try
to reproduce what I did in order to see if it works.
Moritz
> On Tuesday, February 16, 2021, 11:20:31 AM EST, Chris Bartolomei
> <surfcjb at yahoo.com> wrote:
> Well - that does indeed work for you. I'll try your settings when I get
> into the office - we're running GRASS on a RHEL 7 cluster - and see what
> I can come up with.
> It would be sooo much better if it worked like yours did!
> Thank you so much for taking the time and testing this out
> v/r
> Chris
> On Tuesday, February 16, 2021, 11:07:10 AM EST, Moritz Lennert
> On 16/02/21 15:54, Chris Bartolomei wrote:
> > Mortiz - are those vector layers areas ? I'm guessing the census is an
> > area, the roads are lines and the schools are points, yes? I'm having
> > an issue overlaying two area maps (polygons). i can only get one to show
> > ... I have tried your method with all the export GRASS_RENDER* variables
> > but I have a country polygon map as the bottom later and a selection of
> > a few administrative areas (provinces/states) as the top map and I can
> > only get one or the other to show up. It almost seems as if the
> > transparency doesn't work and what should be transparent in the admin
> > map is actually the background color and blocks the country from
> being seen.
> > Could you please try your method with a couple area (polygon) vector
> > maps overlaying each other?
> export GRASS_RENDER_IMMEDIATE=png
> export GRASS_RENDER_WIDTH=640
> export GRASS_RENDER_HEIGHT=480
> export GRASS_RENDER_TRUECOLOR=true
> export GRASS_RENDER_FILE_COMPRESSION=0
> export GRASS_MESSAGE_FORMAT=plain
> export GRASS_RENDER_FILE_READ=TRUE
> export GRASS_RENDER_FILE=$HOME/test.png
> g.region vect=census_wake2000
> d.vect map=census_wake2000 at PERMANENT <mailto:census_wake2000 at PERMANENT>
> fill_color=grey
> d.vect map=censusblk_swwake at PERMANENT
> <mailto:censusblk_swwake at PERMANENT> fill_color=red
> I've tried with
> export GRASS_RENDER_TRANSPARENT=TRUE
> and
> export GRASS_RENDER_TRANSPARENT=FALSE
> As you can see in the attached images, the overlay seems to work without
> any issues (or I don't understand what you are looking for exactly) and
> setting GRASS_RENDER_TRANSPARENT decides on whether the background
> should be transparent or not.
> A second test in the same data set, but with different layers:
> export GRASS_RENDER_FILE=$HOME/test_NC_TRUE.png
> g.region vect=boundary_county
> d.vect map=boundary_county at PERMANENT <mailto:boundary_county at PERMANENT>
> d.vect map=boundary_municp at PERMANENT <mailto:boundary_municp at PERMANENT>
> fill_color=255:255:0:255
> export GRASS_RENDER_FILE=$HOME/test_NC_FALSE.png
> Again, the overlay works, at least as I would have expected.
> Moritz
> > On Tuesday, February 16, 2021, 4:19:16 AM EST, Moritz Lennert
> > <mlennert at club.worldonline.be <mailto:mlennert at club.worldonline.be>>
> wrote:
> > Hi Chris,
> > For me, the following works with the current stable GRASS GIS (7.8.5)
> > and using maps from the NC demo data set:
> > export GRASS_RENDER_TRANSPARENT=true
> <mailto:census_wake2000 at PERMANENT> <mailto:census_wake2000 at PERMANENT
> <mailto:census_wake2000 at PERMANENT>>
> > fill_color=none
> > d.vect map=roadsmajor at PERMANENT <mailto:roadsmajor at PERMANENT>
> <mailto:roadsmajor at PERMANENT <mailto:roadsmajor at PERMANENT>>
> > color=255:0:0:255
> > d.vect map=schools_wake at PERMANENT <mailto:schools_wake at PERMANENT>
> <mailto:schools_wake at PERMANENT <mailto:schools_wake at PERMANENT>>
> > fill_color=0:128:0:255
> > icon=basic/circle size=10
> > I attach a small thumbnail of the resulting PNG file.
> > Moritz
> > On 11/02/21 18:54, Chris Bartolomei via grass-user wrote:
> > > Good morning Anna,
> > > It took quite a while of trial and error but I worked out a method
> that
> > > kindof works:
> > > First off - unless someone says otherwise, you can't use the PNG
> driver
> > > (d.mon) method to overlay more than one polygon vector. Sorry - it
> just
> > > doesn't work. You CAN use the ps.map method - that works really well
> > > generating the image however it by default assumes you are printing on
> > > an A4 piece of paper so there's all sorts of white space. The
> image is
> > > centered at the top of this fictional piece of paper. In your
> postscript
> > > rules file you can use the "maploc" command to position the image
> > > elsewhere on the page. This is necessary because the next trick
> changes
> > > the paper dimensions but it assumes the origin is the lower left
> corner
> > > and therefore clips anything that is above the new dimensions. Back to
> > > postscript commands in the rules file first though ... the ps.map
> maploc
> > > command uses inches (why?? it should be points) so an A4 page is
> 8.27" x
> > > 11.69" points are 1/72 of an inch thus 595p x 842p - it also has a
> > > default 36p margin (0.5 inch). You'll need those numbers later. maploc
> > > also lets you set the size of your image box: maploc {x offset from
> > > left edge} {y offset from top} {width of box} {height of box}
> Note: this
> > > is all done via a BASH script with GRASS 7.4 on Linux (RHEL 7), not
> > > python. This is my postscript rules file:
> > > maploc 0.1 6.815 6.5 4.875 #468p x 351p map box moved down towards the
> > > bottom of the page
> > > # note that if you push it too far down to where the box would run off
> > > the bottom, the image is
> > > # resized to fit on the page so do some testing to come up with the
> > > correct values
> > > # also I found the computational region controls the aspect ratio so
> > > although I say
> > > # 6.5 x 4.875 with the above maploc command, I got a 6.5 x 3.8
> inch box.
> > > border y # add a border to the map frame (box)
> > > color 81:81:81 # shade of gray
> > > end # end the border controls
> > > vareas admin_area # top vector layer to display
> > > layer 1 # attribute table to use
> > > rgbcolumn area_color # name of column holding R:G:B values to fill
> > > the polygons
> > > color 153:153:153 #boundary color
> > > end # end the admin_area controls
> > > vareas Country # this is the bottom vectors to display
> > > color 210:210:210 #boundary color
> > > fcolor 153:153:153 #fill color for all polygons
> > > end # end the Country controls
> > > Here's the command to run to generate the postscript file:
> > > ps.map input=$HOME/ps_rules.txt out=$HOME/color_admin.ps --overwrite
> > > To convert the postscript to PNG I had to use ghostscript - there are
> > > other tools you can use though.
> > > gs -dSAFER -dBATCH -dNOPAUSE -sDEVICE=png16m -r300 -dTextAlphaBits=4
> > > -dGraphicsAlphaBits=4 -dDEVICEWIDTHPOINTS=473 -dDEVICEHEIGHTPOINTS=276
> > > -dFIXEDMEDIA -dPSFitPage -sOutputFile=$HOME/color_admin.png -c
> > > "<</PageOffset [-34 78]>> setpagedevice" -f $HOME/color_admin.ps
> > > So the above line needs some explaining
> > > (http://www.ghostscript.com/doc/9.27/Use.htm
> <http://www.ghostscript.com/doc/9.27/Use.htm >
> <http://www.ghostscript.com/doc/9.27/Use.htm>>) but in a nutshell, the
> > > parameters to play with are first the Pageoffset [x y] values.
> They are
> > > in points not inches ... 1/72 inch = 1 point ... remember the 1/2"
> > > margins? the -34 gives me 2 points of white space to the left edge of
> > > the map frame, the 78 I had to play with to push the map frame down to
> > > the right spot.
> > > Next is the DEVICEWIDTHPOINTS and DEVICEHEIGHTPOINTS ... again in
> points
> > > ... this "trims" the paper to height and width ... set something then
> > > run it and view the results. Adjust and run again until you get it
> > correct.
> > > It's a royal pain but it seems to work this way. It would sure be nice
> > > to create a GRASS workspace file and just say "convert this
> workspace to
> > > an image" with everything all laid out nicely - like Arc does
> exporting
> > > their mxd map files...
> > > I hope this helps someone !
> > > Chris
> > > On Wednesday, February 10, 2021, 11:08:00 PM EST, Anna Petrášová
> > > <kratochanna at gmail.com <mailto:kratochanna at gmail.com>
> <mailto:kratochanna at gmail.com <mailto:kratochanna at gmail.com>>> wrote:
> > > On Tue, Feb 9, 2021 at 4:41 PM Chris Bartolomei <surfcjb at yahoo.com
> <mailto:surfcjb at yahoo.com>
> > <mailto:surfcjb at yahoo.com <mailto:surfcjb at yahoo.com>>
> <mailto:surfcjb at yahoo.com <mailto:surfcjb at yahoo.com>>>> wrote:
> > > Hi Anna - thank you for the suggestion - I tried it but alas, still
> > > it only outputs a single vector map (layer). I can get either the
> > > Country vector or the admin_areas vector, but not both overlaid.
> > > Chris
> > > I realized you are using both environmental variables and d.mon, that
> > > might cause some issues, you use one or the other. So try to
> remove the
> > > lines starting with d.mon.
> > > Hope that helps,
> > > Anna
> > > On Tuesday, February 9, 2021, 1:20:52 PM EST, Anna Petrášová
> <mailto:kratochanna at gmail.com <mailto:kratochanna at gmail.com>>>> wrote:
> > > Hi,
> > > On Tue, Feb 9, 2021 at 10:25 AM Chris Bartolomei via grass-user
> > > <grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>
> <mailto:grass-user at lists.osgeo.org <mailto:grass-user at lists.osgeo.org>>
> <mailto:grass-user at lists.osgeo.org> <mailto:grass-user at lists.osgeo.org
> <mailto:grass-user at lists.osgeo.org>>>>
> > wrote:
> > > Good morning :)
> > > I'm using GRASS 7.4.1 on a Linux cluster so I only have
> > > command-line capability. I have two vector layers (a country
> > > boundary polygon and part of an administrative area map - also
> > > polygons). I am trying to automate creating a PNG file of the
> > > admin areas overlaying the country boundary therefore all work
> > > has to be command-line (in a bash script). I've tried this two
> > > ways - using the d.mon start=png method and also the ps.map
> > > method as described below. The d.mon method appears to generate
> > > the image with only one vector map (not both) and only colors
> > > the borders - it won't use the fill_color setting. The ps.map
> > > method seems to work but assumes the image is on a sheet of
> > > paper so there's a ton of extra white-space. I'd like to use
> > > d.mon but I can use ps.map if someone could please let me know
> > > how to export only the computational region without all the
> > > extra 'paper' in the image. Here's my code:
> > > g.region vector='Country'
> > > export GRASS_RENDER_FILE=$HOME/country_admin.png
> > > d.mon start=png
> > > d.vect map=Country color=210:210:210 fill_color=153:153:153
> > > display=shape type=area
> > > d.vect map=admin_area color=153:153:153 rgb_column=area_color
> > > d.mon stop=png
> > > This only produces a png with the last vector listed and only
> > > the borders are colored with the rgb_column values.
> > > I think you are missing GRASS_RENDER_FILE_READ=TRUE:
> > > https://grass.osgeo.org/grass78/manuals/pngdriver.html
> <https://grass.osgeo.org/grass78/manuals/pngdriver.html >
> <https://grass.osgeo.org/grass78/manuals/pngdriver.html>>
> <https://grass.osgeo.org/grass78/manuals/pngdriver.html>>>
> > > Regarding rgb_column, I am not sure, didn't have time to test.
> > > Anna
> > > If I do this without the d.mon start/stop lines ... i.e.
> relying
> > > on the GRASS_RENDER_IMMEDIATE=png only, then only one
> vector map
> > > is converted to png however it DOES do the color fill properly.
> > > With either above method the png is the correct size.
> > > Now using ps.map (same env variable set as above):
> > > ps.map input=$HOME/ps_rules.txt out=$HOME/country_admin.ps
> > > --overwrite
> > > where ps_rules.txt is:
> > > border y
> > > color 81:81:81
> > > end
> > > vareas admin_area
> > > layer 1
> > > color 153:153:153
> > > end
> > > vareas Country
> > > color 210:210:210
> > > fcolor 153:153:153
> > > end
> > > We don't have pstopng but we do have ghostscript:
> > > gs-dSAFER -dBATCH -dNOPAUSE -sDEVICE=png16m -dTextAlphaBits=4
> > > -dGraphicsAlphaBits=4 -r300
> -sOutputFile=$HOME/country_admin.png
> > > This creates the correct image (color fills, etc) but has white
> > > margins and a lot of white space below the image likeit is
> > > printed at the top of a piece of paper.
> > > does anyone have any idea how to create a png with multiple
> > > vector maps overlaying each other (and not have the extra
> > > whitespace too)?
> > > v/r
> > > Chris
> > > _______________________________________________
> > > grass-user mailing list
> > > https://lists.osgeo.org/mailman/listinfo/grass-user
> <https://lists.osgeo.org/mailman/listinfo/grass-user >
> <https://lists.osgeo.org/mailman/listinfo/grass-user>>
> <https://lists.osgeo.org/mailman/listinfo/grass-user>>>
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210217/41240a3a/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210217/41240a3a/attachment-0001.png>
