[GRASS-user] v.surf.idw Not Working
Micha Silver tsvibar at gmail.com
Thu Feb 18 05:01:53 PST 2021
No solution yet :-(, only more questions...
It looks to me that the plugin is intended to work when the lowres
raster extends the highres raster only in one direction. In your case,
the 1 degree SRTM tile you are using totally contains the USGS 1 meter
region.
To test this I would try to clip out a section of the SRTM:
# Set the computation region to the highres raster, then extend only in
one direction
g.region -p rast=USGS_one_meter_x39y445_IL_12_County_ChampaignCo_2008
g.region -p w=88:20:00W
# Now clip the SRTM to this new region
# But use the coarse resolution
g.region -p res=0:00:01
r.mapcalc "n40_w089_clip = n40_w089_1arc_v3"
# Now try r.mblend with this clipped SRTM
r.mblend high=USGS_one_meter_x39y445_IL_12_County_ChampaignCo_2008
low=n40_w089_clip out=blend
Please report back if this helps (or not...)
On 2/17/2021 2:52 AM, Michaela Lobato wrote:
> Here is the output for r.info <http://r.info> for both maps:
> < r.info <http://r.info>
> map=USGS_one_meter_x39y445_IL_12_County_ChampaignCo_2008 at PERMANENT
> | Map:USGS_one_meter_x39y445_IL_12_Date: Tue Feb 16 18:44:21 2021|
> | Mapset: PERMANENTLogin of Creator: michaelalobato|
> | Location: champaign|
> | DataBase: /Users/michaelalobato/Documents/Research/grassdata |
> | Title:USGS_one_meter_x39y445_IL_12_County_ChampaignCo_2008 |
> | Timestamp: none|
> | Type of Map:raster Number of Categories: 0 |
> | Data Type:FCELL|
> | Rows: 9015 |
> | Columns:11748|
> | Total Cells:105908220|
> |Projection: Latitude-Longitude|
> |N: 40:11:40.173254NS: 40:06:11.010398N Res: 0:00:00.03651 |
> |E: 88:10:23.5766WW: 88:17:32.519389W Res: 0:00:00.036512|
> | Range of data:min = 204.0563max = 244.8284 |
> | Data Description:|
> |generated by r.proj |
> | Comments:|
> |r.proj --quiet location="temp_import_location_4329" mapset="PERMANEN\ |
> |T" input="USGS_one_meter_x39y445_IL_12_County_ChampaignCo_2008" meth\ |
> |od="nearest" memory=300 resolution=1.0142500028210239e-05 |
> < r.info <http://r.info> map=n40_w089_1arc_v3 at PERMANENT
> | Map:n40_w089_1arc_v3 at PERMANENT Date: Tue Feb 16 18:42:24 2021|
> | Title:n40_w089_1arc_v3 |
> | Timestamp: none|
> | Data Type:CELL |
> | Rows: 3601 |
> | Columns:3601 |
> | Total Cells:12967201 |
> |N: 41:00:00.5NS: 39:59:59.5N Res: 0:00:01 |
> |E: 87:59:59.5WW: 89:00:00.5W Res: 0:00:01 |
> | Range of data:min = 163max = 305 |
> | Data Description:|
> |generated by r.in.gdal|
> | Comments:|
> |r.in.gdal -e input="/Users/michaelalobato/Documents/Research/grassda\ |
> |ta/n40_w089_1arc_v3.tif" output="n40_w089_1arc_v3" memory=300 offset\ |
> |=0 num_digits=0 |
> Michalea
Micha Silver
Remote Sensing Lab, Sde Boker
Ben Gurion University
cell: +972-523-665918
