[GRASS-user] v.surf.idw Not Working
Michaela Lobato amlobat2 at illinois.edu
Tue Feb 16 16:52:24 PST 2021
Here is the output for r.info for both maps:
< r.info map=USGS_one_meter_x39y445_IL_12_County_ChampaignCo_2008 at PERMANENT
 | Map:      USGS_one_meter_x39y445_IL_12_  Date: Tue Feb 16 18:44:21 2021
 | Mapset:   PERMANENT                      Login of Creator: michaelalobato
 | DataBase: /Users/michaelalobato/Documents/Research/grassdata
 | Title:    USGS_one_meter_x39y445_IL_12_County_ChampaignCo_2008
 | Timestamp: none
 |   Type of Map:  raster               Number of Categories: 0
 |   Data Type:    FCELL
 |   Rows:         9015
 |   Columns:      11748
 |   Total Cells:  105908220
 |        Projection: Latitude-Longitude
 |            N: 40:11:40.173254N    S: 40:06:11.010398N   Res:
0:00:00.03651 |
 |            E: 88:10:23.5766W    W: 88:17:32.519389W   Res: 0:00:00.036512
 |   Range of data:    min = 204.0563  max = 244.8284
 |   Data Description:
 |    generated by r.proj
 |   Comments:
 |    r.proj --quiet location="temp_import_location_4329" mapset="PERMANEN\
 |    T" input="USGS_one_meter_x39y445_IL_12_County_ChampaignCo_2008" meth\
 |    od="nearest" memory=300 resolution=1.0142500028210239e-05
< r.info map=n40_w089_1arc_v3 at PERMANENT
 | Map:      n40_w089_1arc_v3 at PERMANENT     Date: Tue Feb 16 18:42:24 2021
 | Title:    n40_w089_1arc_v3
 | Timestamp: none
 |   Data Type:    CELL
 |   Rows:         3601
 |   Columns:      3601
 |   Total Cells:  12967201
 |            N: 41:00:00.5N    S: 39:59:59.5N   Res: 0:00:01
 |            E: 87:59:59.5W    W: 89:00:00.5W   Res: 0:00:01
 |   Range of data:    min = 163  max = 305
 |   Data Description:
 |    generated by r.in.gdal
 |   Comments:
 |    r.in.gdal -e input="/Users/michaelalobato/Documents/Research/grassda\
 |    ta/n40_w089_1arc_v3.tif" output="n40_w089_1arc_v3" memory=300 offset\
 |    =0 num_digits=0
Michalea
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210216/04a5e04d/attachment-0001.html>
