[GRASS-user] v.surf.idw Not Working
Micha Silver
tsvibar at gmail.com
Tue Feb 16 11:37:37 PST 2021
On 2/15/21 8:51 PM, Michaela Lobato wrote:
> Thank you for your message. I was able to getv.surf.idw working. I
> posted the original question because I am struggling to use the
> r.mblend add-on module. I have reached out and worked with the
> r.mblend authors on Github but still haven't been able to solve my
> issue. The error I am getting has to do with v.surf.idw:
So you're trying to blend two overlapping rasters of different
resolution? Can we see the output of r.info for both of the rasters?
> Traceback (most recent call last):
> File
> "/Users/michaelalobato/Library/GRASS/7.8/Modules/scripts/r.mblend",
> line 282, in <module>.
> main()
> File
> line 257, in main
> gscript.run_command('v.surf.idw', input=points_edges,
> column=COL_VALUE,
> File
> "/Applications/GRASS-7.8.app/Contents/Resources/etc/python/grass/script/core.py",
> line 441, in run_command
> return handle_errors(returncode, returncode, args, kwargs)
> File
> line 342, in handle_errors
> raise CalledModuleError(module=None, code=code,
> grass.exceptions.CalledModuleError: Module run None v.surf.idw
> input=tmp_3289117 column=value output=tmp_3289118
> power=2 npoints=50 ended with error
> Process ended with non-zero return code -9. See errors in the (error)
> output.
> WARNING: No data base element files found
> WARNING: Table <tmp_3289111> linked to vector map <tmp_3289111> does
> not exist
> The author said that "/The |v.surf.idw| module is failing because it
> can not find the attribute table of one the vector layers. This
> probably means something is going on with the GRASS bank-end
> database./" and requested the following information:
> db.connect -p
> >driver: sqlite
> >database: /Users/michaelalobato/Documents/Research/grassdata/newChampaign/test_champaign/sqlite/sqlite.db
> >schema:
> >group:
> sqlite3
> /Users/michaelalobato/Documents/Research/grassdata/champaign/PERMANENT/sqlite/sqlite.db
> sqlite> .tables
> >sqlite>
> As you can see, when I try to list the existing tables, nothing comes
> up. After this issue, I started working with just v.surf.idwto see if it
The sqlite database is empty since you probably have no vector layers in
your mapset. That's not necessarily a problem.
> might be an issue with the module itself, but that seems to be working
> fine. Does anyone have any suggestions as to how to solve the
> v.surf.idw issue that I'm having within the mblend module?
> Thanks!
> Michaela
> A. Michaela Lobato
> BS Systems Engineering and Design | Autonomous Systems and Robotics |
> December 2019
> MS Systems and Entrepreneurial Engineering | Decision and Control | In
> Progress
> Email: amlobat2 at illinois.edu <mailto:amlobat2 at illinois.edu> | Cell:
> (815) 494-1111
Micha Silver
Ben Gurion Univ.
Sde Boker, Remote Sensing Lab
cell: +972-523-665918
