[GRASS-user] "dbmi: Protocol error" with v.out.ogr
Luís Moreira de Sousa
luis.de.sousa at protonmail.ch
Fri Jan 8 01:11:07 PST 2021
Hi Markus,
the label field was created by r.to.vect, I am not sure of its purpose. For this particular record it contains an empty string (see below).
Thank you.
s4a=# select * from mal9.mal9_5x5_sec_units where cat = 11133509
AND label IS NULL;
cat | mal | label
(0 rows)
s4a=# select LENGTH(label) from mal9.mal9_5x5_sec_units where cat = 11133509;
length
0
(1 row)
s4a=# \d+ mal9.mal9_5x5_sec_units
Table "mal9.mal9_5x5_sec_units"
Column | Type | Collation | Nullable | Default | Storage | Stats target | Description
cat | integer | | | | plain | |
mal | integer | | | | plain | |
label | character varying(10) | | | | extended | |
Indexes:
"mal9_5x5_sec_units_cat" UNIQUE, btree (cat)
Access method: heap
Luís
‐‐‐‐‐‐‐ Original Message ‐‐‐‐‐‐‐
On Thursday, January 7, 2021 12:12 PM, Luís Moreira de Sousa <luis.de.sousa at protonmail.ch> wrote:
> Dear all,
> I have a mapset connected to a Postgres back-end:
>> db.connect -p
> driver: pg
> database: s4a
> schema: mal9
> group:
> In this mapset there is a large points layer that I need to export. I am trying with v.out.ogr:
>> v.out.ogr input=mal9_5x5_sec_units at MAL9 output=/bck/mal9_5x5_sec_units.gpkg format=GPKG
> Exporting 34324866 features...
> ERROR: Cannot select attributes for cat = 11133509
> But the attributes for that geometry are accessible in the back-end:
>> psql -d s4a
> psql (12.5 (Ubuntu 12.5-0ubuntu0.20.04.1))
> Type "help" for help.
> # select * from mal9.mal9_5x5_sec_units where cat = 11133509;
> cat | mal | label
> 11133509 | 0 |
> (1 row)
> What could be causing this error? Is there any other way to export this layer?
> Thank you.
> Luís
> Sent with [ProtonMail](https://protonmail.com) Secure Email.
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210108/d772e2e5/attachment.html>
