[GRASS-user] ITRF92 Not found.
Markus Neteler
neteler at osgeo.org
Thu Mar 18 08:16:51 PDT 2021
On Tue, Mar 16, 2021 at 9:51 AM Markus Neteler <neteler at osgeo.org> wrote:
> Hi,
> On Sun, Mar 14, 2021 at 3:32 PM javier Garcia Prieto
> <fjgarciaprieto at hotmail.com> wrote:
> > Thank you!
> > You are really great! This is going to be so much useful to Mexican people, You are very kind.
> Glad to help. Now it is merged, i.e. it is already available in the
> current source code of GRASS GIS 7.8.git and will be part of GRASS GIS
> 7.8.6 and later.
BTW, I made a test which you indicated to me off-list, with the
udpated GRASS GIS 7.8.git version:
gdalinfo republica2017_r15m.bil
Driver: EHdr/ESRI .hdr Labelled
Files: republica2017_r15m.bil
republica2017_r15m.bil.ovr
republica2017_r15m.bil.aux.xml
republica2017_r15m.hdr
republica2017_r15m.stx
republica2017_r15m.prj
Size is 218763, 130943
Coordinate System is:
GEOGCRS["ITRF92",
DATUM["International Terrestrial Reference Frame 1992",
ELLIPSOID["GRS 1980",6378137,298.257222101,
LENGTHUNIT["metre",1]],
ID["EPSG",6651]],
PRIMEM["Greenwich",0,
ANGLEUNIT["Degree",0.0174532925199433]],
CS[ellipsoidal,2],
AXIS["longitude",east,
ORDER[1],
AXIS["latitude",north,
ORDER[2],
ANGLEUNIT["Degree",0.0174532925199433]]]
Data axis to CRS axis mapping: 1,2
Origin = (-117.124268882302502,32.718626154577500)
Pixel Size = (0.000138888889000,-0.000138888889000)
Corner Coordinates:
Upper Left (-117.1242689, 32.7186262) (117d 7'27.37"W, 32d43' 7.05"N)
Lower Left (-117.1242689, 14.5320984) (117d 7'27.37"W, 14d31'55.55"N)
Upper Right ( -86.7405189, 32.7186262) ( 86d44'25.87"W, 32d43' 7.05"N)
Lower Right ( -86.7405189, 14.5320984) ( 86d44'25.87"W, 14d31'55.55"N)
Center (-101.9323939, 23.6253623) (101d55'56.62"W, 23d37'31.30"N)
Band 1 Block=218763x1 Type=Int16, ColorInterp=Undefined
Min=-32.000 Max=5610.000
Minimum=-32.000, Maximum=5610.000, Mean=1041.610, StdDev=820.476
NoData Value=-32768
Overviews: 109382x65472, 54691x32736, 27346x16368, 13673x8184,
6837x4092, 3419x2046, 1710x1023, 855x512, 428x256, 214x128
Metadata:
SourceBandIndex=0
STATISTICS_SKIPFACTORX=1
STATISTICS_SKIPFACTORY=1
# generate location from dataset
grass78 -c republica2017_r15m.bil /mnt/data/grassdata/mexico
# verify projection
GRASS 7.8.6dev (mexico):~ > g.proj -w
GEOGCRS["ITRF92",
ID["EPSG",6651]],
CS[ellipsoidal,2],
ORDER[1],
ORDER[2],
# import DEM
r.import republica2017_r15m.bil output=republica2017_r15m
# set color table
r.colors republica2017_r15m color=srtm_plus
The result looks good to me.
best,
Markus
