[GRASS-user] error in g.extension while installing i.fusion.hpf in windows
    Veronica Andreo
    veroandreo at gmail.com
    Sun Mar 21 09:36:29 PDT 2021
Thanks both!
So the solution in the meantime is to:
1. download the zip file from
https://wingrass.fsv.cvut.cz/grass78/x86_64/addons/latest/
2. unzip and remove the __pychache__ folder
3. copy everything to C:\Users\YourUserName\AppData\Roaming\GRASS7\addons\
Is that correct?
I hope the g.extension problem can be fixed soon? @Helli would you mind
opening an issue for that, please?
Cheers,
Vero
El sáb, 20 mar 2021 a las 23:33, <nik at nikosalexandris.net> escribió:
> That's great Helmut :-)
> Nikos
> On 2021-03-19 22:39, Helmut Kudrnovsky wrote:
> > the script itself (downloaded from
> > https://wingrass.fsv.cvut.cz/grass78/x86_64/addons/latest/) works.
> > now we have to solve the g.extension issue.
> > kind regards
> > helli
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210321/796a5c25/attachment.html>
