[GRASS-user] error in g.extension while installing i.fusion.hpf in windows
    Helmut Kudrnovsky
    hellik at web.de
    Sun Mar 21 12:07:31 PDT 2021
>So the solution in the meantime is to:
>1. download the zip file from https://wingrass.fsv.cvut.cz/grass78/x86_64/addons/latest/
>2. unzip and remove the __pychache__ folder
>3. copy everything to C:\Users\YourUserName\AppData\Roaming\GRASS7\addons\
yes; the contents of following folders
D:\dl\i.fusion.hpf>dir /b
bin
docs
etc
scripts
into the corresponding folders in C:\Users\YourUserName\AppData\Roaming\GRASS7\addons\
>@Helli would you mind opening an issue for that, please?
done: https://github.com/OSGeo/grass/issues/1477
ciao
helli
