[GRASS-user] Loading LPC data in GRASS
Maris Nartiss maris.gis at gmail.com
Thu Mar 25 00:25:58 PDT 2021
The r.in.pdal from the PR is totally different beast than one located
in add-ons.
It is quite common for LAS files to lack coordinate system
information. In a such case it is your responsibility to handle its
correctness. If your location is in the same coordinate system as LAS
files, just use -o flag to ignore this error. If coordinate system of
your location and LAS files does not match, specify it with input_srs
parameter.
Good luck,
Māris.
2021-03-24 22:23 GMT+02:00, Andreas Yankopolus <andreas at yank.to>:
> Maris,
>> r.in.pdal still lacks metadata printing functionality and thus has not
>> been merged into the main branch yet. You can get the code from this PR:
>> https://github.com/OSGeo/grass/pull/1200
> I switched to that PR with "git-pr 1200”, and the resulting binary has
> r.in.pdal.
> Trying the tutorial in
> https://grass.osgeo.org/grass78/manuals/addons/r.in.pdal.html
> <https://grass.osgeo.org/grass78/manuals/addons/r.in.pdal.html>, I get the
> following error message when trying to read a .laz file with r.in.pdal:
> 	ERROR: The input dataset has undefined projection
> I have pdal installed locally and am not using a Docker container for it.
> What should I be doing differently to load LPC data?
> Thanks,
> Andreas
