[GRASS-user] Building grass version grass-7.8.5
    Moritz Lennert
    mlennert at club.worldonline.be
    Sat Mar 27 03:07:02 PDT 2021
Am 26. März 2021 23:13:18 MEZ schrieb Stephen Kirby <thinjogger at gmail.com>:
>Thanks Veronica for that good information.  I've made some progress by
>ensuring I had the libs it needs ready (GDAL, etc.).  Now it is giving me a
>Python error :
> File
>"/home/me/grass/dist.x86_64-pc-linux-gnu/etc/python/grass/script/core.py",
>line 305,
>**options,
>SyntaxError: invalid syntax
>I am not a Python user so this is throwing me.  I assume I need to install
>a Python (Python3?) module, via "pip install ..." I suppose.  Can someone
>tell me which module can fix this?
>For reference, the whole Python block of code containing the offending
>line, from core.py is:
>def make_command(
> prog,
> flags="",
> overwrite=False,
> quiet=False,
> verbose=False,
> superquiet=False,
> errors=None,
> **options,
AFAICT there should not be a comma after **options. This would explain the syntax error.
Moritz
