[GRASS-user] winGRASS tester needed ... to fix upcoming releases :-) .... nobody out there willing to test?
    Maria Cecilia Zalazar
    zalazarmariacecilia at gmail.com
    Thu May  6 13:47:19 PDT 2021
Dear Grass community, I´m using wingrass 7.8.5 (daily, mainly to process
and analyze raster DEM). No new issues to report in my daily task.  But if
I try to install i.fusion.hpf, as Helmut suggested, I obtain the following
error message. I hope it is useful. Best regards
Downloading precompiled GRASS Addons <i.fusion.hpf>...
Fetching <i.fusion.hpf> from <
http://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.5/i.fusion.hpf.zip>
(be patient)...
  File
"C:\OSGeo4W64\apps\grass\grass78/scripts/g.extension.py",
line 2350, in <module>
    sys.exit(main())
  File
line 2330, in main
    install_extension(source=source, url=url, xmlurl=xmlurl,
branch=branch)
  File
line 871, in install_extension
    ret1, new_modules_ext, new_files_ext =
install_extension_win(extension)
  File
line 1259, in install_extension_win
    for line in file:
  File "C:\OSGeo4W64\apps\Python37\lib\fileinput.py", line
252, in __next__
    line = self._readline()
366, in _readline
    return self._readline()
  File "C:\OSGeo4W64\apps\Python37\lib\encodings\cp1252.py",
line 23, in decode
    return
codecs.charmap_decode(input,self.errors,decoding_table)[0]
UnicodeDecodeError: 'charmap' codec can't decode byte 0x9d
in position 401: character maps to <undefined>
El jue, 6 de may. de 2021 a la(s) 17:27, Helmut Kudrnovsky (hellik at web.de)
escribió:
> mail below was sent on Wed Apr 14 2021 => no reaction, no one a minute to
> test?
> if no one of the community has a minute to test winGRASS, then I guess
> it's time to propose to the PSC dropping winGRASS at all....
> kind regards
> Helmut
> dear GRASS GIS community,
> testing of winGRASS is a important piece of puzzle to guarantee a stable
> and useable software on the MS windows platform in the future.
> For this, we would need the help of the community now. :-)
> background is an _error in g.extension while installing i.fusion.hpf in
> windows_
> some more information
> https://github.com/OSGeo/grass/issues/1477
> https://github.com/OSGeo/grass/pull/1496
> it's an encoding issue while opening files via python.
> a possible solution may be set PYTHONUTF8=1 as environment variable.
> and a way how you could help, just add
> set PYTHONUTF8=1
> in C:\OSGeo4W64\apps\grass\grass79\etc\env.bat just before GRASS_PYTHON is
> set. (or in the same file in the standalone winGRASS installation).
> it would look like:
> set PYTHONUTF8=1
> set GRASS_PYTHON=%OSGEO4W_ROOT%\bin\python3.exe
> and then happy GRASS GIS working :-) and report back if there are any
> issues in your daily winGRASS work.
> kind regards
> Helmut
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210506/333c9f5e/attachment.html>
