[GRASS-user] winGRASS tester needed ... to fix upcoming releases :-) .... nobody out there willing to test?
Maria Cecilia Zalazar zalazarmariacecilia at gmail.com
Thu May 6 14:11:53 PDT 2021
Sorry.... and If I added  "set PYTHONUTF8=1" in
C:\OSGeo4W64\apps\grass\grass78\etc\env.bat just before GRASS_PYTHON is
setting,
grass stops to work...
[image: image.png]
El jue, 6 de may. de 2021 a la(s) 17:47, Maria Cecilia Zalazar (
zalazarmariacecilia at gmail.com) escribió:
> Dear Grass community, I´m using wingrass 7.8.5 (daily, mainly to process
> and analyze raster DEM). No new issues to report in my daily task.  But if
> I try to install i.fusion.hpf, as Helmut suggested, I obtain the following
> error message. I hope it is useful. Best regards
> Downloading precompiled GRASS Addons <i.fusion.hpf>...
> Fetching <i.fusion.hpf> from <
> http://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.5/i.fusion.hpf.zip>
> (be patient)...
> Traceback (most recent call last):
>   File
> "C:\OSGeo4W64\apps\grass\grass78/scripts/g.extension.py",
> line 2350, in <module>
>     sys.exit(main())
>   File
> line 2330, in main
>     install_extension(source=source, url=url, xmlurl=xmlurl,
> branch=branch)
>   File
> line 871, in install_extension
>     ret1, new_modules_ext, new_files_ext =
> install_extension_win(extension)
>   File
> line 1259, in install_extension_win
>     for line in file:
>   File "C:\OSGeo4W64\apps\Python37\lib\fileinput.py", line
> 252, in __next__
>     line = self._readline()
> 366, in _readline
>     return self._readline()
>   File "C:\OSGeo4W64\apps\Python37\lib\encodings\cp1252.py",
> line 23, in decode
>     return
> codecs.charmap_decode(input,self.errors,decoding_table)[0]
> UnicodeDecodeError: 'charmap' codec can't decode byte 0x9d
> in position 401: character maps to <undefined>
> El jue, 6 de may. de 2021 a la(s) 17:27, Helmut Kudrnovsky (hellik at web.de)
> escribió:
>> mail below was sent on Wed Apr 14 2021 => no reaction, no one a minute to
>> test?
>> if no one of the community has a minute to test winGRASS, then I guess
>> it's time to propose to the PSC dropping winGRASS at all....
>> kind regards
>> Helmut
>> dear GRASS GIS community,
>> testing of winGRASS is a important piece of puzzle to guarantee a stable
>> and useable software on the MS windows platform in the future.
>> For this, we would need the help of the community now. :-)
>> background is an _error in g.extension while installing i.fusion.hpf in
>> windows_
>> some more information
>> https://github.com/OSGeo/grass/issues/1477
>> https://github.com/OSGeo/grass/pull/1496
>> it's an encoding issue while opening files via python.
>> a possible solution may be set PYTHONUTF8=1 as environment variable.
>> and a way how you could help, just add
>> set PYTHONUTF8=1
>> in C:\OSGeo4W64\apps\grass\grass79\etc\env.bat just before GRASS_PYTHON
>> is set. (or in the same file in the standalone winGRASS installation).
>> it would look like:
>> set PYTHONUTF8=1
>> set GRASS_PYTHON=%OSGEO4W_ROOT%\bin\python3.exe
>> and then happy GRASS GIS working :-) and report back if there are any
>> issues in your daily winGRASS work.
>> kind regards
>> Helmut
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210506/d78826f3/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210506/d78826f3/attachment-0001.png>
