[GRASS-user] . winGRASS tester needed ... to fix upcoming releases
karsten
karsten at terragis.net
Fri May 7 11:44:12 PDT 2021
With PYTHONUTF8=1 set in the bat, I imported some rasters and created a map
in GRASS 7.8.5, all fine.
The only thing I found so far was when trying to close Grass I got an
windows OS error message that read 'Python stopped working' . I could not
find an error.log for this so far
Karsten
-----Original Message-----
Sent: Friday, May 07, 2021 11:33
To: 'grass-user at lists.osgeo.org'
Subject: RE: . winGRASS tester needed ... to fix upcoming releases
On my windows 10 machine and using Grass version 7.8.5 I have added set
PYTHONUTF8=1 to the bat file and Grass is starting up fine. I will report
any issues that I'll find
Cheers
Karsten
From: grass-user [mailto:grass-user-bounces at lists.osgeo.org] On Behalf Of
grass-user-request at lists.osgeo.org
Sent: Thursday, May 06, 2021 14:12
To: grass-user at lists.osgeo.org
Subject: grass-user Digest, Vol 181, Issue 3
Send grass-user mailing list submissions to
To subscribe or unsubscribe via the World Wide Web, visit
https://lists.osgeo.org/mailman/listinfo/grass-user
or, via email, send a message with subject or body 'help' to
You can reach the person managing the list at
grass-user-owner at lists.osgeo.org
When replying, please edit your Subject line so it is more specific than
"Re: Contents of grass-user digest..."
Today's Topics:
1. winGRASS tester needed ... to fix upcoming releases :-) ....
nobody out there willing to test? (Helmut Kudrnovsky)
2. Re: winGRASS tester needed ... to fix upcoming releases :-)
.... nobody out there willing to test? (Maria Cecilia Zalazar)
3. Re: winGRASS tester needed ... to fix upcoming releases :-)
Message: 1
Date: Thu, 6 May 2021 22:20:23 +0200
Subject: [GRASS-user] winGRASS tester needed ... to fix upcoming
releases :-) .... nobody out there willing to test?
Message-ID:
<trinity-050dd24e-81ac-4865-a0a1-ebf5a0c3161b-1620332423809 at 3c-app-webde-bap
16>
Content-Type: text/plain; charset=UTF-8
mail below was sent on Wed Apr 14 2021 => no reaction, no one a minute to
test?
if no one of the community has a minute to test winGRASS, then I guess it's
time to propose to the PSC dropping winGRASS at all....
kind regards
Helmut
dear GRASS GIS community,
testing of winGRASS is a important piece of puzzle to guarantee a stable and
useable software on the MS windows platform in the future.
For this, we would need the help of the community now. :-)
background is an _error in g.extension while installing i.fusion.hpf in
windows_
some more information
https://github.com/OSGeo/grass/issues/1477
https://github.com/OSGeo/grass/pull/1496
it's an encoding issue while opening files via python.
a possible solution may be set PYTHONUTF8=1 as environment variable.
and a way how you could help, just add
set PYTHONUTF8=1
in C:\OSGeo4W64\apps\grass\grass79\etc\env.bat just before GRASS_PYTHON is
set. (or in the same file in the standalone winGRASS installation).
it would look like:
set PYTHONUTF8=1
set GRASS_PYTHON=%OSGEO4W_ROOT%\bin\python3.exe
and then happy GRASS GIS working :-) and report back if there are any issues
in your daily winGRASS work.
kind regards
Helmut
Message: 2
Date: Thu, 6 May 2021 17:47:19 -0300
From: Maria Cecilia Zalazar <zalazarmariacecilia at gmail.com>
To: Helmut Kudrnovsky <hellik at web.de>
Cc: grass-user at lists.osgeo.org
Subject: Re: [GRASS-user] winGRASS tester needed ... to fix upcoming
Message-ID:
<CADLxGovin56s+qdzPDbtRqLXrQqwnq55CSfPcY9RaNfD2SOOmw at mail.gmail.com>
Content-Type: text/plain; charset="utf-8"
Dear Grass community, I?m using wingrass 7.8.5 (daily, mainly to process and
analyze raster DEM). No new issues to report in my daily task. But if I try
to install i.fusion.hpf, as Helmut suggested, I obtain the following error
message. I hope it is useful. Best regards
Downloading precompiled GRASS Addons <i.fusion.hpf>...
Fetching <i.fusion.hpf> from <
http://wingrass.fsv.cvut.cz/grass78/x86_64/addons/grass-7.8.5/i.fusion.hpf.z
ip>
(be patient)...
File
"C:\OSGeo4W64\apps\grass\grass78/scripts/g.extension.py",
line 2350, in <module>
sys.exit(main())
File
line 2330, in main
install_extension(source=source, url=url, xmlurl=xmlurl,
branch=branch)
File
line 871, in install_extension
ret1, new_modules_ext, new_files_ext =
install_extension_win(extension)
File
line 1259, in install_extension_win
for line in file:
File "C:\OSGeo4W64\apps\Python37\lib\fileinput.py", line 252, in __next__
line = self._readline()
File "C:\OSGeo4W64\apps\Python37\lib\fileinput.py", line 366, in _readline
return self._readline()
File "C:\OSGeo4W64\apps\Python37\lib\encodings\cp1252.py",
line 23, in decode
return
codecs.charmap_decode(input,self.errors,decoding_table)[0]
UnicodeDecodeError: 'charmap' codec can't decode byte 0x9d in position 401:
character maps to <undefined>
El jue, 6 de may. de 2021 a la(s) 17:27, Helmut Kudrnovsky (hellik at web.de)
escribi?:
> to test?
> it's time to propose to the PSC dropping winGRASS at all....
> kind regards
> Helmut
> stable and useable software on the MS windows platform in the future.
> in windows_
> set PYTHONUTF8=1
> GRASS_PYTHON is set. (or in the same file in the standalone winGRASS
installation).
> it would look like:
> set PYTHONUTF8=1
> issues in your daily winGRASS work.
> kind regards
> Helmut
URL:
<http://lists.osgeo.org/pipermail/grass-user/attachments/20210506/333c9f5e/a
ttachment-0001.html>
Message: 3
Date: Thu, 6 May 2021 18:11:53 -0300
Message-ID:
<CADLxGot2c4-42Zs3uEHKPNa20FH=H85=C6yg51Qfa4vUsGg5gw at mail.gmail.com>
Sorry.... and If I added "set PYTHONUTF8=1" in
C:\OSGeo4W64\apps\grass\grass78\etc\env.bat just before GRASS_PYTHON is
setting, grass stops to work...
[image: image.png]
El jue, 6 de may. de 2021 a la(s) 17:47, Maria Cecilia Zalazar (
zalazarmariacecilia at gmail.com) escribi?:
> process and analyze raster DEM). No new issues to report in my daily
> task. But if I try to install i.fusion.hpf, as Helmut suggested, I
> obtain the following error message. I hope it is useful. Best regards
> .hpf.zip>
> (be patient)...
> File
> sys.exit(main())
> File
> line 2330, in main
> branch=branch)
> File
> File
> for line in file:
> __next__
> _readline
> line 23, in decode
> return
> 401: character maps to <undefined>
> (hellik at web.de)
> escribi?:
>> minute to test?
>> guess it's time to propose to the PSC dropping winGRASS at all....
>> kind regards
>> Helmut
>> in windows_
>> set PYTHONUTF8=1
installation).
>> it would look like:
>> set PYTHONUTF8=1
>> kind regards
>> Helmut
URL:
<http://lists.osgeo.org/pipermail/grass-user/attachments/20210506/d78826f3/a
ttachment.html>
Type: image/png
Desc: not available
URL:
ttachment.png>
Subject: Digest Footer
End of grass-user Digest, Vol 181, Issue 3
