[GRASS-user] Load Grass vector file into geopandas-fiona
JUAN SEBASTIAN VINASCO SALINAS vinasco.juan at correounivalle.edu.co
Tue May 11 08:47:41 PDT 2021
Hello everyone,
I am trying to read a vector file stored in a GRASS database from
geopandas-fiona.
import fiona
import geopandas as gpd
fiona.supported_drivers["OGR_GRASS"] = "r"
gdf =
gpd.read_file('/mnt/d/Datos_Landsat/nc_basic_spm_grass7/PERMANENT/vector/roadsmajor/head')
However it seems that fiona support for GRASS data is not enabled by
default. And the suggested activation does not work.  I get the following
error
  File "fiona/_shim.pyx", line 73, in fiona._shim.gdal_open_vector
  File "fiona/_err.pyx", line 270, in fiona._err.exc_wrap_pointer
fiona._err.CPLE_OpenFailedError:
not recognized as a supported file format.
During handling of the above exception, another exception occurred:
  File "<stdin>", line 1, in <module>
  File
"/home/juan/miniconda3/envs/iota2-env/lib/python3.6/site-packages/geopandas/io/file.py",
line 76, in read_file
    with reader(path_or_bytes, **kwargs) as features:
  File
"/home/juan/miniconda3/envs/iota2-env/lib/python3.6/site-packages/fiona/env.py",
line 397, in wrapper
    return f(*args, **kwargs)
  File
"/home/juan/miniconda3/envs/iota2-env/lib/python3.6/site-packages/fiona/__init__.py",
line 253, in open
    layer=layer, enabled_drivers=enabled_drivers, **kwargs)
  File
"/home/juan/miniconda3/envs/iota2-env/lib/python3.6/site-packages/fiona/collection.py",
line 159, in __init__
    self.session.start(self, **kwargs)
  File "fiona/ogrext.pyx", line 484, in fiona.ogrext.Session.start
  File "fiona/_shim.pyx", line 80, in fiona._shim.gdal_open_vector
fiona.errors.DriverError:
I think it is possible that the OGR build does not include the driver to
read GRASS GIS data, but this is new ground for me. does anyone have
experience with this integration?
I am running on a WSL2 and on a conda environment created with the
following packages:
- https://anaconda.org/iota2/grass (grass7.7)
- https://anaconda.org/iota2/otb (Orfeo Toolbox 7.1)
Regards,
Juan
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210511/484ed80c/attachment.html>
