[GRASS-user] v.select disjoint operation. Grass 7.8.2
    Christopher Lloyd
    chrislloyd2 at yahoo.co.uk
    Wed May 19 06:29:46 PDT 2021
 Hi Markus, Thanks for your response. I note that another user recently had a similar error with a similar (but not the same) module.
I am currently splitting my input data into smaller sized files, each for input separately to the v.select module, to see if this resolves the issue. I will let you know on progress. If the failure continues then I will supply you with a reproducible example using the NC data as you indicate. Many thanks.
Best wishes, Chris    On Tuesday, 18 May 2021, 22:01:58 BST, Markus Neteler <neteler at osgeo.org> wrote:
Is there a chance to receive the dataset for testing (or, ideally, a
reproducible example with the North Carolina sample dataset from
https://grass.osgeo.org/download/data/)?
thanks,
Markus
On Wed, May 12, 2021 at 1:14 PM Christopher Lloyd via grass-user
<grass-user at lists.osgeo.org> wrote:
> Hi, I am running Grass 7.8.2 on a HPC (linux) to utilise memory not available to me via my local machine.
> It is running using proj 6.3, gdal 3.0.4, geos 3.8, python 3
> I am trying to perform the v.select disjoint operation, which I have used successfully before on a similar setup and similar data using the same version of Grass (I suspect only the supporting modules and input data have changed). My code is:
> g.region n=5.4715700149536133 e=31.4501590728759766 s=-13.5662746429443359 w=12.1540479660034180 -p
> ## Input and clean topology
> v.in.ogr -e -o input=file.json output=filev2 snap=-1 --verbose --overwrite
> v.in.ogr -e -o input=file2.gpkg output=file2 snap=-1 --verbose --overwrite encoding=UTF-8
> ## Extract all categories for each dataset so as to maintain polygon (building) contiguity where polygons overlap other polygons within each dataset
> v.extract -d input=filev2 layer=1 type=centroid,area output=buildingsdiss --verbose --overwrite
> v.extract -d input=file2 layer=1 type=centroid,area output=file2diss1 where="cat < 6000001" --verbose --overwrite
> ## Perform disjoint operation to find buildings that do not intersect buildings in primary dataset
> v.select ainput=file2diss1 alayer=file2diss1 binput=buildingsdiss blayer=buildingsdiss output=DISJOINT1 operator=disjoint --verbose --overwrite
> ## Output disjoint building layer and cleaned primary dataset
> v.out.ogr -m input=DISJOINT1 output=DISJOINT1.gpkg --verbose --overwrite
> v.out.ogr -m input=filev2 output=filev2.gpkg --verbose --overwrite
> Having input the topologies and extracted the categories I persistently get the following error using various data when trying to run the disjoint operation:
> projection: 3 (Latitude-Longitude)
> zone:      0
> datum:      wgs84
> ellipsoid:  wgs84
> north:      5:28:17.649311N
> south:      13:33:58.588333S
> west:      8:09:27.521013W
> east:      51:45:42.670764E
> nsres:      1:00:07.170402
> ewres:      1:00:56.104945
> rows:      19
> cols:      59
> cells:      1121
> NS and EW resolutions are different
> Processing features...
>    0%..........100%
> Processing areas...
>    0% ERROR: Unable to seek: Invalid argument
> Any advice appreciated on getting v.select to run. Thanks
> Best wishes, Chris
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://courses.neteler.org/blog
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210519/0650275d/attachment-0001.html>
