[GRASS-user] v.select disjoint operation. Grass 7.8.2
Christopher Lloyd
chrislloyd2 at yahoo.co.uk
Thu May 20 04:59:59 PDT 2021
Hi Markus, Having split my input data into smaller sized shp files, these now process fine using v.select. So clearly the problem that I had lies with some file size limitation with the v.select 'disjoint' algorithm - also failing with one input file prior using the v.extract algorithm. The original (large) input files input to grass ok using v.in.ogr, but then failed when using v.select. Might you be able to indicate the file size limitation for the v.select algorithm and the reasons for this? Thanks.
Best wishes, Chris
On Wednesday, 19 May 2021, 14:29:56 BST, Christopher Lloyd via grass-user <grass-user at lists.osgeo.org> wrote:
Hi Markus, Thanks for your response. I note that another user recently had a similar error with a similar (but not the same) module.
I am currently splitting my input data into smaller sized files, each for input separately to the v.select module, to see if this resolves the issue. I will let you know on progress. If the failure continues then I will supply you with a reproducible example using the NC data as you indicate. Many thanks.
Best wishes, Chris On Tuesday, 18 May 2021, 22:01:58 BST, Markus Neteler <neteler at osgeo.org> wrote:
Is there a chance to receive the dataset for testing (or, ideally, a
reproducible example with the North Carolina sample dataset from
https://grass.osgeo.org/download/data/)?
thanks,
Markus
On Wed, May 12, 2021 at 1:14 PM Christopher Lloyd via grass-user
> Hi, I am running Grass 7.8.2 on a HPC (linux) to utilise memory not available to me via my local machine.
> It is running using proj 6.3, gdal 3.0.4, geos 3.8, python 3
> I am trying to perform the v.select disjoint operation, which I have used successfully before on a similar setup and similar data using the same version of Grass (I suspect only the supporting modules and input data have changed). My code is:
> g.region n=5.4715700149536133 e=31.4501590728759766 s=-13.5662746429443359 w=12.1540479660034180 -p
> ## Input and clean topology
> v.in.ogr -e -o input=file.json output=filev2 snap=-1 --verbose --overwrite
> v.in.ogr -e -o input=file2.gpkg output=file2 snap=-1 --verbose --overwrite encoding=UTF-8
> ## Extract all categories for each dataset so as to maintain polygon (building) contiguity where polygons overlap other polygons within each dataset
> v.extract -d input=filev2 layer=1 type=centroid,area output=buildingsdiss --verbose --overwrite
> v.extract -d input=file2 layer=1 type=centroid,area output=file2diss1 where="cat < 6000001" --verbose --overwrite
> ## Perform disjoint operation to find buildings that do not intersect buildings in primary dataset
> v.select ainput=file2diss1 alayer=file2diss1 binput=buildingsdiss blayer=buildingsdiss output=DISJOINT1 operator=disjoint --verbose --overwrite
> ## Output disjoint building layer and cleaned primary dataset
> v.out.ogr -m input=DISJOINT1 output=DISJOINT1.gpkg --verbose --overwrite
> v.out.ogr -m input=filev2 output=filev2.gpkg --verbose --overwrite
> Having input the topologies and extracted the categories I persistently get the following error using various data when trying to run the disjoint operation:
> projection: 3 (Latitude-Longitude)
> zone: 0
> datum: wgs84
> ellipsoid: wgs84
> north: 5:28:17.649311N
> south: 13:33:58.588333S
> west: 8:09:27.521013W
> east: 51:45:42.670764E
> nsres: 1:00:07.170402
> ewres: 1:00:56.104945
> rows: 19
> cols: 59
> cells: 1121
> NS and EW resolutions are different
> Processing features...
> 0%..........100%
> Processing areas...
> 0% ERROR: Unable to seek: Invalid argument
> Any advice appreciated on getting v.select to run. Thanks
> Best wishes, Chris
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
Markus Neteler, PhD
https://www.mundialis.de - free data with free software
https://courses.neteler.org/blog
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20210520/7d2ab43b/attachment.html>
