[GRASS-user] v.select disjoint operation. Grass 7.8.2
Markus Neteler
neteler at osgeo.org
Thu May 20 08:48:02 PDT 2021
Hi Chris,
On Thu, May 20, 2021 at 2:00 PM Christopher Lloyd
<chrislloyd2 at yahoo.co.uk> wrote:
> Hi Markus, Having split my input data into smaller sized shp files, these now process fine using v.select. So clearly the problem that I had lies with some file size limitation with the v.select 'disjoint' algorithm - also failing with one input file prior using the v.extract algorithm. The original (large) input files input to grass ok using v.in.ogr,
The vector limit is as follows:
https://grasswiki.osgeo.org/wiki/GRASS_GIS_Performance#Large_vector_data_processing
--> In all GRASS versions, the limit with topology is at time 2^31 - 1
(about 2 billion) features per vector map.
> but then failed when using v.select. Might you be able to indicate the file size limitation for the v.select algorithm and the reasons for this? Thanks.
This said, perhaps v.select lacks a proper declaration?
Could you tell us how many vector features per map you are dealing
with (say: those which work and those which fail)?
Best wishes, Markus
