[GRASS-user] d.mon start=cairo multi-layer PDF, PS, SVG output
Luigi Ponti
luisponti at tiscali.it
Tue Nov 9 06:47:40 PST 2021
Dear list,
I am replying to myself just to say that I hit the same issues as shown at:
https://trac.osgeo.org/grass/ticket/3033
My apologies for not checking that first.
As I keep running into this problem, but there is not a lot of discussion
on it, probably people have found other ways to deal with it (e.g., ps.map,
which what I will try next).
Also, I noticed that the Python way was also explored:
https://discuss.wxpython.org/t/wx-image-postscript/25813
which I was actually about to ask…
Kind regards,
Luigi
On Thu, Oct 28, 2021 at 12:34 PM Luigi Ponti <luisponti at tiscali.it> wrote:
> Dear all,
> I am trying to get output image files in various formats using the Cairo
> driver, following some very useful Python scripting examples:
> https://baharmon.github.io/python-in-grass
> When I try to map vector layers (e.g., point data) on top of raster layers
> (say a digital elevation model);
> if I use PNG output file extension, both vector and raster layers show up
> with points having transparent background,
> if I use PDF, PS, or SVG output file extension, only the vector layer
> (drawn last) is shown in the output image with white background.
> Maybe the PS driver is a better option?
> Yet, I was reading this old grass-dev post that may be relevant:
> https://marc.info/?l=grass-dev&m=146346954429631&w=2
> Kind regards,
> Luigi
> Sample test function I am using follows:
> def make_map(outfile_name,
> fig_width,
> fig_height,
> bg_color: Optional[str] = None,
> file_types: Optional[list] = None):
> """ Test ouput map figure.
> PLEASE CHECK as PDF and PS output does not get vectors displayed on
> top of rasters. """
> background_color = bg_color or [NO_BG_COLOR]
> extensions = [PNG] if file_types is None else file_types
> for extension in extensions:
> outfile = pathlib.Path(OUT_DIR).joinpath(f"{outfile_name}.{extension}")
> grass.run_command("d.mon", overwrite=True,
> start="cairo",
> width=fig_width,
> height=fig_height,
> bgcolor=background_color,
> output=outfile)
> grass.run_command("d.rast",
> map="raster_layer")
> grass.run_command("d.vect",
> map="point_vector_layer",
> type="point",
> color="150:0:0",
> size=20)
> # all other display commands
> grass.run_command("d.mon", stop="cairo")
> Bundled GRASS app for Mac from here:
> http://grassmac.wikidot.com/downloads
> System Info:
> GRASS version: 8.0.dev
> Code revision: 32930185c
> Build date: 2021-07-01
> Build platform: x86_64-apple-darwin20.5.0
> GDAL: 3.1.4
> PROJ: 7.1.1
> GEOS: 3.8.1
> SQLite: 3.35.4
> Python: 3.8.8
> wxPython: 4.1.1
> Platform: macOS-10.16-x86_64-i386-64bit
> g.version -b
> GRASS 8.0.dev (2021)
> ./configure
> --with-macosx-sdk=/Library/Developer/CommandLineTools/SDKs/MacOSX10.14.sdk
> --enable-64bit --with-macosx-archs=x86_64 --with-opengl=aqua --with-openmp
> --prefix=/Applications/GRASS-8.0.app/Contents/Resources --with-freetype
> --with-freetype-includes=/Applications/GRASS-8.0.app/Contents/Resources/include/freetype2
> --with-freetype-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-gdal=/Applications/GRASS-8.0.app/Contents/Resources/bin/gdal-config
> --with-gdal-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-proj=/Applications/GRASS-8.0.app/Contents/Resources/bin/proj
> --with-proj-includes=/Applications/GRASS-8.0.app/Contents/Resources/include
> --with-proj-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-proj-share=/Applications/GRASS-8.0.app/Contents/Resources/share/proj
> --with-geos=/Applications/GRASS-8.0.app/Contents/Resources/bin/geos-config
> --with-jpeg-includes=/Applications/GRASS-8.0.app/Contents/Resources/include
> --with-jpeg-libs=//Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-png-includes=/Applications/GRASS-8.0.app/Contents/Resources/include
> --with-png-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-tiff-includes=/Applications/GRASS-8.0.app/Contents/Resources/include
> --with-tiff-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-postgres=yes
> --with-postgres-includes=/Applications/GRASS-8.0.app/Contents/Resources/include
> --with-postgres-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --without-mysql --with-sqlite
> --with-sqlite-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-sqlite-includes=/Applications/GRASS-8.0.app/Contents/Resources/include
> --with-fftw-includes=/Applications/GRASS-8.0.app/Contents/Resources/include
> --with-fftw-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-cxx --with-cairo
> --with-cairo-includes=/Applications/GRASS-8.0.app/Contents/Resources/include/cairo
> --with-cairo-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-cairo-ldflags=-lcairo --with-zstd
> --with-zstd-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-zstd-includes=/Applications/GRASS-8.0.app/Contents/Resources/include
> --with-bzlib
> --with-bzlib-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-bzlib-includes=/Applications/GRASS-8.0.app/Contents/Resources/include
> --with-netcdf=/Applications/GRASS-8.0.app/Contents/Resources/bin/nc-config
> --with-blas
> --with-blas-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-blas-includes=/Applications/GRASS-8.0.app/Contents/Resources/include
> --with-lapack
> --with-lapack-includes=/Applications/GRASS-8.0.app/Contents/Resources/include
> --with-lapack-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-nls --with-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-includes=/Applications/GRASS-8.0.app/Contents/Resources/include
> --with-pdal=/Applications/GRASS-8.0.app/Contents/Resources/bin/pdal-config
> --with-pdal-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-readline
> --with-readline-includes=/Applications/GRASS-8.0.app/Contents/Resources/include/readline
> --with-readline-libs=/Applications/GRASS-8.0.app/Contents/Resources/lib
> --with-liblas=/Applications/GRASS-8.0.app/Contents/Resources/bin/liblas-config
> Luigi Ponti
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211109/8a3b5f87/attachment.html>
