[GRASS-user] v.in.ascii column identifications
Rich Shepard
rshepard at appl-ecosys.com
Fri Oct 1 09:06:48 PDT 2021
The 8.0.dev manual for v.in.ascii describes the column identifiers:
x=integer
Number of column used as x coordinate (points mode)
First column is 1
Default: 1
y=integer
Number of column used as y coordinate (points mode)
First column is 1
Default: 2
z=integer
Number of column used as z coordinate (points mode)
First column is 1. If 0, z coordinate is not used
Default: 0
Entering v.in.ascii on the command line (lines wrapped in alpine):
v.in.ascii -z
in=~/projects/washington/project/data/bathymetry/coe/CL_33_LDYX_20210712_CS.xyz
out=lady_xsec_depths for=point x=1 y=2 z=3 col='x double precision, y double
precision, z integer' --o
yields this response from GRASS:
WARNING: ntokens: 1, xcol: 0, ycol: 1, zcol: 2
ERROR: Broken row 2: '7709581.42,697951.64,24'
When I change the command to match the above:
ERROR: Column numbers must not be negative
GRASS project/bathymetry:analyses > ERROR: Column numbers must not be negative
And when I try it again:
bash: GRASS: command not found
What might be going on here? Now neither the command line nor the GUI will
import an ASCII point file.
Rich
