[GRASS-user] Elevation values display
Maria Cecilia Zalazar
zalazarmariacecilia at gmail.com
Sat Oct 2 13:06:40 PDT 2021
Hello, try doing double click on the legend (in pointer mode) to set object
properties. You can set the number of digits after decimal point (zero in
your case).
Cecilia
El sáb, 2 de oct. de 2021 a la(s) 16:51, Rich Shepard (
rshepard at appl-ecosys.com) escribió:
> The bathymetric data have depths (z values) as integers. When displayed in
> the GUI display window they are floating point values each ending in .00. I
> don't find where that's controlled. Since they're close together I'd like
> to
> display only the integer portion of each value.
> Can I do this?
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211002/eb46de2f/attachment.html>
