[GRASS-user] Display behavior of table attribute data
Paulo van Breugel
p.vanbreugel at gmail.com
Wed Oct 6 14:28:52 PDT 2021
That is, I guess, because sqlite 'uses dynamic typing. It does not enforce
data type constraints. Data of any type can (usually) be inserted into any
column. '?
On October 6, 2021 5:25:47 PM Rich Shepard <rshepard at appl-ecosys.com> wrote:
> I learned something surprising this morning using a combination of the GUI
> management window's map 'display table attributes' and db.execute.
> The two adjacent bathymetric point files imported with a Z-int column with
> type double precision for the integer depths. However, the depth values
> displayed are in double precision format (ending in .00).
> I added a new column, depth_int (type int), and copied (using SQL's 'alter
> table') the Z-int double precision values to the depth_int column, then
> deleted the Z-int column. The GUI's attribute table management dialog
> confirmed that the depth_int is of type integer.
> After re-displaying these maps the depth values are still double precision
> while the column data type is integer. Oh well.
> Rich
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211006/84c4a5c8/attachment.html>
