[GRASS-user] Startup menu small. Why?
Hernán De Angelis
variablestarlight at gmail.com
Wed Oct 13 00:14:41 PDT 2021
Hola Vero
Thank you for your answer. I use openSUSE Tumbleweed (rolling release,
updates very frequently). I have the following installation:
System Info
GRASS version: 7.8.6
Code revision: exported
Build date: 2021-10-13
Build platform: x86_64-pc-linux-gnu
GDAL: 3.3.2
PROJ: 8.1.0
GEOS: 3.9.1
SQLite: 3.36.0
Python: 3.8.12
wxPython: 4.1.1
Platform: Linux-5.14.9-1-default-x86_64-with-glibc2.34
When resizing I see this kind of messages on the terminal:
(gis_set.py:22469): Gtk-WARNING **: 09:02:24.924: Negative content
height -5 (allocation 5, extents 5x5) while allocating gadget (node
button, owner GtkButton)
(gis_set.py:22469): Gtk-WARNING **: 09:02:25.188: Negative content
height -2 (allocation 8, extents 5x5) while allocating gadget (node
(gis_set.py:22469): Gtk-CRITICAL **: 09:02:25.245:
gtk_box_gadget_distribute: assertion 'size >= 0' failed in GtkScrollbar
(gis_set.py:22469): Gtk-CRITICAL **: 09:02:25.289:
To me this is not too serious, I have seen this before when the startup
screen had the right size. I believe that if other users are not
experiencing this may be it is not worth pursuing a fix at all, as GRASS
8 does not have this startup screen anymore.
Best
Hernán
Den 2021-10-12 kl. 20:30, skrev Veronica Andreo:
> Hola Hernán,
> Which OS do you use and which version of wxpython? I compiled the
> release branch today and here, in my fedora 34 with Python 3.9.7 and
> wxPython 4.0.7, I don't have that issue. Maybe worth a bug report?
> best,
> Vero
> El mar, 12 oct 2021 a las 17:43, Hernán De Angelis
> (<variablestarlight at gmail.com>) escribió:
> Dear grassers
> I compiled and installed 7.8.6 yesterday. Everything seemed to go
> well and GRASS works as good as ever. However, a small nuisance
> that I am experiencing is that the startup menu window shows up
> sort of "minimized", instead of the classical larger size showing
> the locations and mapsets from which to choose:
> I have to manually increase its size to what formally was a normal
> size in order to see which location and mapset to choose:
> This is not a problem, just a minor nuisance. And perhaps GRASS is
> not even involved in this but rather something else related with
> wxPython etc.
> Has anyone experienced this before? Does someone has any idea on
> how to overcome this?
> Thanks in advance
> Hernán
> grass-user mailing list
> https://lists.osgeo.org/mailman/listinfo/grass-user
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211013/718b9bea/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211013/718b9bea/attachment-0002.png>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/grass-user/attachments/20211013/718b9bea/attachment-0003.png>
