[GRASS-user] v.in.ogr ESRI fileGDB
Rich Shepard
rshepard at appl-ecosys.com
Fri Sep 17 15:37:59 PDT 2021
On Fri, 17 Sep 2021, Moritz Lennert wrote:
> I saw that you found a different solution, but just for the record: are
> you sure the fgdb actually contains vector data ? AFAIR, fgdb's can also
> contain raster data, but there is no gdal driver for that.
Moritz,
The alternative solution is less desirable.
I've no idea how to determine if the fileGDB holds vector or raster data.
I've looked through the gdal web site and didn't see how to determine the
type of data. But, I've assumed the .atx files in the directory ar vector.
There are also several TIFF files:
tile_e_dem_tif.aux.xml
tile_e_dem_tif.tfw
tile_e_dem_tif.tif
tile_e_dem_tif.tif.ovr
tile_e_dem_tif.tif.xml
I've not tried r.in.gdal; will do so over the weekend.
BTW, I don't know what Vero changed in the web site but for the 8.0dev
manual the GRASS startup page link in the General category still produces a
404 page not found.
Stay well,
Rich
